Go to Post the rookies come up with amazing stuff (I have seen it happening), they amaze me at times. - Arefin Bari [more]
Unread 16-07-2015, 19:49
grosh grosh is offline
FRC #2147
grosh is an unknown quantity at this point
Code won't deploy
When I try to deploy our LV code we get an error that the target can't be found. What is confusing is that the driver station says we have communication and is pinging the robot. We could not get to the webdashboard with roboRIO-team.local but can using 172.22.11.2 . We updated the roboRIO firmware through the webdashboard and reimage the roboRIO using the imaging tool.
Any ideas?
Unread 16-07-2015, 20:32
Re: Code won't deploy
What target address (in parentheses) is associated with the RT deployment in the LabVIEW project?
Unread 16-07-2015, 20:49
FRC #2147
(roboRIO-2147.local)
Unread 17-07-2015, 19:30
Jonathan L. Jonathan L. is offline
Programmer alumnus, mentor, and CSA
FRC #1094 (Channel Cats)
Jonathan L. is a jewel in the roughJonathan L. is a jewel in the roughJonathan L. is a jewel in the roughJonathan L. is a jewel in the rough
Are you using a separate computer than your programming computer for the Driver Station or is it the same computer?
What communication method are you using between the computer(s) and the roboRIO (USB, Ethernet, Wireless)? If you are using Ethernet make sure you are going though the d-link not direct to the roboRIO.
If you are using a USB cable with the programming computer then change the ip address you are deploying to, to be 172.22.11.2
Unread 19-07-2015, 01:58
If 172.22.11.2 works, that suggests that you're using a USB connection to the roboRIO instead of Ethernet. Does the Driver Station connect successfully over Ethernet? Can you ping the roboRIO-2147.local address? Is your computer configured for DHCP ("obtain IP address automatically" or something like that)? Is the roboRIO Ethernet set properly to "DHCP and link local"?
Originally Posted by Jonathan L. View Post
If you are using a USB cable with the programming computer then change the ip address...
No, don't do that. The mDNS name should be used regardless. The symptoms described seem to say that the mDNS support isn't working right on the programming computer. That's the part that should be fixed.
Unread 19-07-2015, 11:43
FRC #2147
Code won't deploy
I am connected with the USB cord. Works now when I turn off the computers wireless. Don't know why but it works.
Thanks
Unread 19-07-2015, 12:16
orangelight's Avatar
orangelight orangelight is offline
AKA: Alex
FRC #0548 (Robostangs)
orangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to behold
Do you have mDNS client installed on the computer?
Unread 19-07-2015, 23:38
If you're going to be connected by wire, you should disable the wireless adapter. Windows and LabVIEW do not always manage to pick the right network hardware when more than one is active.
