Go to Post Do what you want. Deal with the results. - Andy Baker [more]
Unread 17-07-2015, 19:30
Jonathan L. Jonathan L. is offline
FRC #1094
Jonathan L. is a jewel in the roughJonathan L. is a jewel in the roughJonathan L. is a jewel in the roughJonathan L. is a jewel in the rough
Re: Code won't deploy
Are you using a separate computer than your programming computer for the Driver Station or is it the same computer?
What communication method are you using between the computer(s) and the roboRIO (USB, Ethernet, Wireless)? If you are using Ethernet make sure you are going though the d-link not direct to the roboRIO.
If you are using a USB cable with the programming computer then change the ip address you are deploying to, to be 172.22.11.2
