Go to Post The only thing more dangerous than a Programmer with a screwdriver is a Hardware Designer with the root password... - kmcclary [more]
Unread 20-07-2015, 19:31
Cherry254 Cherry254 is offline
Cherry254 has much to be proud ofCherry254 has much to be proud ofCherry254 has much to be proud ofCherry254 has much to be proud ofCherry254 has much to be proud ofCherry254 has much to be proud ofCherry254 has much to be proud ofCherry254 has much to be proud ofCherry254 has much to be proud of
Team 254 Presents: Deadlift Technical Binder 2015
Team 254 Presents: Deadlift Technical Binder. The binder can be found here. If you have any questions or want more specifications, feel free to ask!
Unread 20-07-2015, 19:33
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
Re: Team 254 Deadlift Technical Binder 2015
Finally! Is code next?
Unread 20-07-2015, 19:43
Code will be coming out soon!
Unread 20-07-2015, 19:50
AKA: Ahad Bawany
no team (None)
1.How are the carriages driven up and down? They appear to be attached to timing belts through some type of clip?
2. What type of bearings did you use for your elevator?
3. What types of belt did you use in your elevator?
4. How did you install your chain in the tubing?
5. Are you using the talon srx or victor SP?
Unread 20-07-2015, 19:59
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
*effect
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
Unread 20-07-2015, 20:30
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
This is a great resource! Thank you for releasing it.
Unread 20-07-2015, 20:39
Jared's Avatar
Jared Jared is offline
As always, the design binder is amazing.
I've got a few questions about the design process and the robot itself.
From what I can see, you guys have almost all of the robot in CAD before you start making parts for systems other than drive. At what point in the season do you finish drivebase CAD and the rest of the CAD? How many people do you have on your CAD team, and how long do they work to get it done?
Finally, does your team use any type of version control for SolidWorks, either EPDM or workgroup? If so, what type of server/computer does it run on?
It looks like you had no way to adjust chain tension this year. Would you recommend running a chain in tube drive system with no tensioners in a more aggressive game, or would you probably switch back to an adjustable and accessible design?
I've also seen your team run 3mm pitch pulleys off the output shaft of the RS-775 motors many times. Are these pulleys you make yourselves with a press fit for the motor shaft, or are they something else?
What material was used for the friction brakes?
Unread 20-07-2015, 20:44
kgzak's Avatar
kgzak kgzak is offline
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
When you release the code will the simulator also be released? I'd love to see it.
Unread 20-07-2015, 22:34
wendells's Avatar
wendells wendells is offline
FRC #2185 (RAMAZOIDZ)
wendells is a name known to allwendells is a name known to allwendells is a name known to allwendells is a name known to allwendells is a name known to allwendells is a name known to all
Thank You Team 254! Simple and effective process.
Unread 20-07-2015, 22:36
AKA: Ahad Bawany
no team (None)
Is it just me, or did one of 254's mentors post a reply, only for it to disappear?
Knufire Knufire is offline
If you guys are willing, I'd love a more in depth overview of the brake system used.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 20-07-2015, 22:39
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
I did. Alex will add to what I had. He had some additional insight specific to the assembly and maintenance.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 21-07-2015, 00:02
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
If I recall correctly from my visit to their pit in St. Louis, it's dead simple. Literally just metal on metal contact when the piston is engaged. The pressure and friction are enough to stop the elevator.
Unread 21-07-2015, 01:39
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
When I looked at it, it looked like there was an odd rough brown material, not something like aluminum on aluminum.
Unread 21-07-2015, 02:06
Engineering Mentor
FRC #0254
We used 410 Stainless Steel to make a "disc" that pushed against a High Friction Molded Brake & Clutch Lining Sheet. It works just like a disc brake, except the forces are applied axially about the point of rotation.
As you can see, the disc spins and slides on a 3/8" hex shaft. This allowed us to install the disc brake outside of the gearbox. It was the smallest solution we could come up with.
See below:
-Travis Covington
