Go to Post i have a feeling that the field with be the same as it was last year just to save some money. but what is inside the the field will be diferent. - Michael Leicht [more]
Unread 21-07-2015, 02:06
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Re: Team 254 Deadlift Technical Binder 2015
Originally Posted by asid61 View Post
When I looked at it, it looked like there was an odd rough brown material, not something like aluminum on aluminum.
We used 410 Stainless Steel to make a "disc" that pushed against a High Friction Molded Brake & Clutch Lining Sheet. It works just like a disc brake, except the forces are applied axially about the point of rotation.
As you can see, the disc spins and slides on a 3/8" hex shaft. This allowed us to install the disc brake outside of the gearbox. It was the smallest solution we could come up with.
See below:
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
