Go to Post Mind you... if your ball kicker has as much energy stored up as a trackball launcher, you ought to be able to kick balls up into the stands. - dtengineering [more]
Go Back   Chief Delphi > Announcements
Thread Tools Rating: Thread Rating: 11 votes, 5.00 average. Display Modes
  #181   Spotlight this post!
Unread 20-07-2015, 17:09
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Re: BattleBots Return - And They're Powered by VEXpro!
Originally Posted by dodar View Post
Am I the only one who finds Ghost Raptor matches boring?
No. I feel like the de-icer is getting overhyped. It didn't stop Icewave from hitting them. Ghost Raptor was able to take the hit, but the match was pretty much over in 15 seconds. Not very exciting.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
  #182   Spotlight this post!
Unread 21-07-2015, 01:34
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Originally Posted by Loose Screw View Post
Ghost Raptor's horizontal spinner was sheared in half during one of their previous fights.
I don't know how much time they have between rounds, but the deicer seemed to be perfectly designed for Icewave. Did they bring that to the event, or design and manufacture it entirely between rounds? If the latter is the case, then it's highly likely that they'll have another redesign tailor made for their opponent. I like how much freedom they have when it comes to redesigns.
It was made on site between matches.
2001-2004: Team 100
2006-Present: Team 254
  #183   Spotlight this post!
Unread 21-07-2015, 06:32
Loose Screw's Avatar
Loose Screw Loose Screw is offline
A Loose Screw
AKA: Chris
FTC #5237 (Loose Screws)
Loose Screw is a jewel in the roughLoose Screw is a jewel in the roughLoose Screw is a jewel in the rough
Wow, that's very impressive. Do you know how much time they have in between matches?
  #184   Spotlight this post!
Unread 21-07-2015, 10:10
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
It was basically a last ditch effort from a team not willing to let a huge setback kill them. It probably . . . shouldn't have won it for them, but I think the fact that Icewave's blade had to bounce around between Ghost Raptor's ramp and the de-icer made all the difference. The fact that Icewave was lifted off the ground while its blade bounced around against Ghost Raptor and it's de-icer threw it off balance too much.
Though I was rooting for Icewave, the de-icer was one of those great "not going down without a fight" / "crazy enough to work" moments.
  #185   Spotlight this post!
Unread 21-07-2015, 12:23
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Originally Posted by Monochron View Post
... the de-icer was one of those great "not going down without a fight" / "crazy enough to work" moments.
I tend to look at more in terms of what they should have been doing all along, whenever facing a spinner.
Po-taa-toe vs Poe-tah-toe
Tastes great vs Less filling
etc.
  #186   Spotlight this post!
Unread 21-07-2015, 12:59
The other Gabe's Avatar
The other Gabe The other Gabe is offline
Too many events, not enough time
AKA: I'm a volunteer now!
no team (2046 Bear Metal Alumn)
The other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud of
Originally Posted by Bryce2471 View Post
In my opinion, what you just described is the best strategy for defeating a powerful spinner...
+1: in a battle with Tombstone; tombstone will cause most of the damage. now whether it causes this to itself, or its opponent...
Do the best you can with what you are given
FRC 2046 2012-2015
Field Scout lead 2014-2015
  #187   Spotlight this post!
Unread 21-07-2015, 13:03
Originally Posted by Michael Hill View Post
It seemed like Bronco's driver isn't exactly the best one there. Watching the match last night, it looked like he didn't have much field awareness (kept running into obstacles on the field and walls), but perhaps it's just a small sample size issue. Also, I'm going to assume that Tombstone has at least one more weapon and that they have time to put it on, so I'm leaning pretty heavily on Tombstone winning that match.
Bronco's driver is great: look up T-minus or Toro from the old battlebots- there's some more extended battles that show his skill better. I think that he just assumed that the field hazards wouldn't come up, since they were pretty much non existent in previous matches. and tombstone used his shorter blade vs witch doctor, so he still has 1 left
FRC 2046 2012-2015
  #188   Spotlight this post!
Unread 21-07-2015, 13:59
Amanda Morrison's Avatar Unsung FIRST Hero
Amanda Morrison Amanda Morrison is offline
16 awesome years of FRC!
Amanda Morrison has a reputation beyond reputeAmanda Morrison has a reputation beyond reputeAmanda Morrison has a reputation beyond reputeAmanda Morrison has a reputation beyond reputeAmanda Morrison has a reputation beyond reputeAmanda Morrison has a reputation beyond reputeAmanda Morrison has a reputation beyond reputeAmanda Morrison has a reputation beyond reputeAmanda Morrison has a reputation beyond reputeAmanda Morrison has a reputation beyond reputeAmanda Morrison has a reputation beyond repute
Turns out the writers at Vice produced an article that provides the meat of my earlier argument, albeit in much more eloquent fashion. Beware strong language in some parts of the article.
Battlebots is Sports All Right, and It's Amazing
Literally the only thing I've been upset about has been the lack of ABC announcing the second season. I think this experiment in bringing back Battlebots to prime-time television has been an incredible success.
Director of Operations, VEX Robotics, Inc.
Alumna - Teams 71, 1020, 1720, 148
2002 World Champions (Team 71) | 2008 World Champions (Team 148)
  #189   Spotlight this post!
Unread 21-07-2015, 15:40
Cory's Avatar
AKA: Cory McBride
Depended on what point in the tournament it was. Probably 18 hours between the first fight and second fight, then around 2-4 hours for each subsequent one.
2001-2004: Team 100
  #190   Spotlight this post!
Unread 21-07-2015, 20:48
DonShaw DonShaw is offline
FRC #1261
DonShaw is a glorious beacon of lightDonShaw is a glorious beacon of lightDonShaw is a glorious beacon of lightDonShaw is a glorious beacon of lightDonShaw is a glorious beacon of lightDonShaw is a glorious beacon of light
I really hope VEX considers giving FIRST and run for their money by getting a large robot competition going. I believe First needs some competition and we need more choices in the large robot format.
  #191   Spotlight this post!
Unread 26-07-2015, 21:52
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Wow! What a finals!
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
  #192   Spotlight this post!
Unread 26-07-2015, 21:58
PayneTrain's Avatar
PayneTrain PayneTrain is online now
Trickle-Down CMP Allocation
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
You're in for a treat West Coast!
See y'all next week to see who wins BattleBots in Detroit!
Wait...
  #193   Spotlight this post!
Unread 26-07-2015, 21:59
dodar's Avatar
Wait...
Ha!
  #194   Spotlight this post!
Unread 26-07-2015, 22:03
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
Wait...
Remember what site you're on! CD members have been known to go off on people for comments like that
  #195   Spotlight this post!
Unread 26-07-2015, 22:04
Hallry's Avatar
Hallry Hallry is offline
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
You obviously have never met Wil Payne before...
