Go to Post What's so bad about Matt? I mean, if the guy can explain PID so that even I can understand it, he can't be all that bad... - Billfred [more]
Unread 21-07-2015, 14:25
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Question for onborad compressor teams
Did you run your compressor through the COMPRESSOR OUT terminals on the PCM, or did you use a Spike instead? If you ran off of the PCM, did you run into any problems with small wire and high continuous current draw from the compressor?
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 21-07-2015, 14:57
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Re: Question for onborad compressor teams
This was actually talked about at length in the beta feedback session at CMP. The bottom line from Omar and Mike (CTRE) is that there have not been any issues but if you find one then let them know so they can re-create it.
Unread 21-07-2015, 15:05
M3rcuriel's Avatar
M3rcuriel M3rcuriel is offline
AKA: Lee Mracek
FRC #0299 (Valkyrie Robotics)
M3rcuriel is on a distinguished road
If you want anecdotal evidence along with the above, my team used an on-board compressor all year without a Spike, and had no problems.
Unread 21-07-2015, 15:12
feverittm's Avatar
feverittm feverittm is offline
FRC #0997 (Spartans)
feverittm will become famous soon enoughfeverittm will become famous soon enough
Our Team also ran the smaller Vlair compressor all season connected through the PCM without any issues with the compressor or the fuse. Our only issue is that the wire gauge requirements on the power terminals for the PCM are smaller than I believe they should be. Not because of current, but because of compatibility across all the modules.
Floyd Moore
Mentor Electrical and Pneumatics
Team 997 - Spartan Robotics
Corvallis High School, Corvallis Oregon
Unread 21-07-2015, 15:26
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
We ran the larger viair all season through the PCM without any problems. We also tested the smaller viair and an older Thomas compressor on the PCM during alpha and beta testing, both without any issues.
2016: Lake Superior WFFA
Unread 21-07-2015, 15:30
jajabinx124's Avatar
jajabinx124 jajabinx124 is offline
Team 2052 Alumni
AKA: Kshitij Wavre
jajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond repute
For this year, Team 2052 used the Spike to run our on-board compressor(250C-IG) instead of the compressor out terminals on the PCM. We used the Spike instead because we were worried about the high current draw from the compressor as well.
FRC Volunteer CSA (MRI off-season event, 2017 Lake Superior Regional, 2017 10,000 Lakes Regional) 2016 - Present
FRC 2052 KnightKrawler (Team Captain, Strategist, Scouting, Programming) 2013 - 2016
1 Division Win & Einstein Appearance
3 Division Quarter-Finalists
1 Regional Chairman's Award
5 Regional Wins, 3 Regional Finalists
3 MN State Championship Wins, 1 MN State Championship Finalist
Thanks to all our alliance partners who krawled with us: 41, 70, 225, 525, 1595, 2054, 2062, 2122, 2175, 2227, 2472, 2526, 2883, 2990, 3018, 3244, 3276, 3310, 3313, 3360, 3538, 3692, 4011, 4198, 4536, 4607, 4778, 5172, 5690
Unread 21-07-2015, 15:33
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
No issues. Took a while to jam the compressor wires into the thing, but it works fine.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 21-07-2015, 16:17
Sparky3D's Avatar
Sparky3D Sparky3D is offline
AKA: Dustin D
FRC #1736 (Robot Casserole)
Sparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of light
We spent an ridiculous amount of time trying to wire the smaller Viair compressor directly to the PCM. We would think we had the wires in securely, but they would always come loose again after driving the robot for any length of time. We ended up having to add a connector and run a short length of smaller gauge wire to the PCM. I REALLY wish they would have made those terminals a bit larger.
Unread 21-07-2015, 21:15
TogetherSword8 TogetherSword8 is offline
FRC #0888 (Robotiators)
TogetherSword8 is an unknown quantity at this point
We also ran the wires into the PCM. Although we originally tried to use larger gauge wire (I think 14, can't quite remember) we had to swap it to 16 for the same reason as above. Other than that, we never had a problem with running the compressor though the PCM. Just problems with 1 and 2 year-olds pulling on the wires.
I program a robot. Which means I write code and everyone gets mad at me when something doesn't work, even if I am the only one that knows it doesn't work. The key part to know is that the robot never works.
Unread 21-07-2015, 21:35
Gregor's Avatar
Gregor Gregor is online now
#StickToTheStratisQuo
AKA: Gregor Browning
We ran the baby VIAR off a spike as a precaution given the new hardware, but I'd probably wire it straight to the PCM in future years given that there were no problems that I heard of.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 21-07-2015, 21:43
mman1506's Avatar
mman1506 mman1506 is online now
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
We had a ton of issues with blowing the fuse on the PDB while using a Thomas compressor off the PCM. We had to be pulled off the field a couple of times due the fuse blowing while pre-charging. It could be that our compressor is faulty and has a exceptionally high startup current but I'd really like to see a more robust solution in the future.
2016: FRC 865 Mentor
Unread 21-07-2015, 22:07
Melchior Vester's Avatar
Melchior Vester Melchior Vester is offline
FRC #0027 (Team RUSH)
Melchior Vester is an unknown quantity at this point
Team 27 has been using it all during beta season and during the 2015 season and haven't ran into any problems running the compressor off the PCM
2013 - 2015 Mechanical/Electrical, Pit Crew
Michigan Tech
Unread 22-07-2015, 07:31
marshall's Avatar
Do you still have that compressor? If so then you should get in touch with Mike Copioli from CTRE. He was offering up his left arm for examples of this at the beta feedback talk IIRC.
Unread 22-07-2015, 07:50
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
We used the small Viair as an onboard compressor off the PCM for the entire season and never ran into a problem with it once. We had a huge amount of air storage this year because your lift was completely pneumatic (2 18" throw 1.5" d pistons) so we used the compressor a lot beyond its recommended specs. Since it takes us about 3-5 minutes to charge between matches, we often ran it longer than recommended. We even ran it almost continuously for over half an hour between matches and pre-charging and never once ran into a problem.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 22-07-2015, 09:21
Per the 2015 rules, you were allowed to run the PCM off one of the 20A breakers, it didn't have to go through that fuse... Try switching it and see if you still have problems, assuming you have everything setup still. Keep in mind that teams that did go through the fuse were combining the compressor load with anything they had hooked up to the VRM, so it may not be solely the compressor that was blowing the fuse, it was just the piece that sent you over the top.
