Re: pic: 6in Butterfly Module With Piston
Interesting module, I would also like to see how cantilevering it works out. Make sure you test that before the season starts if you plan on having it as a possibility. Last edited by Darkseer54 : 21-07-2015 at 20:40. Reason: Unhappy brother is unhappy. This is octocanum. |
Two things,
First, I too am skeptical of cantilevering the module for stability. I have no doubt that the plates would be fine structurally but I could see where your wheels may want to bend the module and possibly loosen some of the bolts as well as not turn smoothly. Second, I assume the traction wheels are 3 in, am I right? I am certainly no expert on this kind of drive and the cantilever may perform wonderfully, I would just have to see in running to be in full support of cantilevering the module. I love the idea behind this sort of drive train and I would love to see a video and real life weight once you actually have it working. |
Also relevant is which wheel set -- traction or omni -- was on the pivot axle.
