Re: Setting up a second router for practicing
You can run the robot/robots through a primary router by just bridging the radios to the primary routers. If you are using 2 roborios, you have to reconfigure the 2nd roborio to have a different domain name. The easiest way would be to change the team number on the 2nd roborio.
The upside of bridging like this is that all devices have access to the internet and you can push code without changing networks. |
