Go to Post All I can say is - we are such geeks! - Raul [more]
Unread 26-07-2015, 15:20
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
Which sensors should be used throughout the robot?
Note: This is in response to a disucssion I had with 971's technical mentor, thanks for the help!
I've been wondering what sensors are the "best" for certain areas of the robot. The areas I'm thinking of are: Fly wheels, Elevators, turrets, and drivetrains.
What different sensors have you used for these applications, and how have you found them?
P.S. Has anyone used the S4t? Am I right in my assumption that it doesn't rotate?
Unread 26-07-2015, 15:36
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Which sensors should be used throughout the robot?
That's about like asking what is the best gear ratio: it depends.
And speaking of depends, that's proven to be the most critical feature when it comes to selecting which limit switch, encoder, camera, potentiometer, rangefinder, or optical interrupt (we've used all of these at one time or another) -- that it be dependable. A flaky sensor is often worse than none at all.
We've gotten sensors from AndyMark, RobotShop, Lynxmotion, Adafruit, Mouser, Jameco, McMaster-Carr, and even Radio Shack. We even played with some magnetic reed switches from Home Depot or Lowes. That's probably not a complete list.
Unread 26-07-2015, 15:53
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
We've had good experiences with the AMT-102 encoders, which are inexpensive and robust.
We also like these reed switches for proximity or limit sensors. They're easy to mount and more durable than mechanical switches.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 26-07-2015, 16:11
AKA: Ahad Bawany
no team (None)
How exactly are the reed switches programmed? Same as limit switches?
Thanks for the feedback so far, keep it coming. Would like to use the same sensor *encoder, ir, ect* in as many places as possible!
Unread 26-07-2015, 16:18
Custom User Title
AKA: Cal
Yes.
Unread 26-07-2015, 16:21
Knufire Knufire is online now
I've used the S4 in several different applications. Can you clarify what you mean by doesn't rotate?
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Encoders such as Greyhills or S4s on drive and elevators. Some teams like 10 turn pots on elevators, but I think encoders are easier. Then hall effects for indexing, or anywhere you would use a limit switch. Pots work better for arms because indexing an arm is hard. Any type of object indexing we use beam break sensors, which we buy from Adafruit. Then for shooters you either need a fast reacting beam break, or the smallest CPR encoder you can find.
Team 4488 - Mentor 2013-2016
Unread 26-07-2015, 16:22
jajabinx124's Avatar
jajabinx124 jajabinx124 is offline
Team 2052 Alumnus
AKA: Kshitij Wavre
jajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond repute
Reed switches and limit switches are both digital inputs that return boolean states, so both would be programmed the same.
FRC Volunteer CSA (MRI off-season event, 2017 Lake Superior Regional, 2017 10,000 Lakes Regional) 2016 - Present
FRC 2052 KnightKrawler (Team Captain, Strategist, Scouting, Programming) 2013 - 2016
1 Division Win & Einstein Appearance
3 Division Quarter-Finalists
1 Regional Chairman's Award
5 Regional Wins, 3 Regional Finalists
3 MN State Championship Wins, 1 MN State Championship Finalist
Thanks to all our alliance partners who krawled with us: 41, 70, 225, 525, 1595, 2054, 2062, 2122, 2175, 2227, 2472, 2526, 2883, 2990, 3018, 3244, 3276, 3310, 3313, 3360, 3538, 3692, 4011, 4198, 4536, 4607, 4778, 5172, 5690
Unread 26-07-2015, 16:30
AKA: Ahad Bawany
no team (None)
I seem to have misunderstood this sentence on the us digital website, sorry! "The S4T miniature optical shaft encoder is a non-contacting rotary to digital converter." My lack of experience with shaft encoders let me to assume that this meant the encoder literally doesn't rotate.
Have you ever experimented with beam breaks for shooters? Any issues with programming or voltage (I've heard a few don't work below 12v?)
Note: To clarify, you mean limiting the range of something by indexing? Like using a limit switch to stop an elevator?
Unread 26-07-2015, 16:36
We used beam breaks in 2012 and 2013 for our shooters. I don't know which models, but they were easy to use, and we didnt have any trouble. They were 5V models though, but since we now have a regulated 12V from the VRM, 12V ones should be fine too.
I probably used the wrong word for indexing. For elevators and arms, if using an encoder, you have to have a limit switch/hall effect at some point to zero it. And that is harder with arms then with elevators.
Unread 26-07-2015, 16:39
The silver shaft rotates. You mount the encoder with a nut on the brass-colored threaded portion, which will also hold the black housing stationary.
Unread 26-07-2015, 16:52
AKA: Ahad Bawany
no team (None)
From what I've seen, most teams just mount these by drilling a quarter inch hole and putting them in. How does the shaft still spin with the axle if the hole is a larger diameter than it is?
Unread 26-07-2015, 16:55
So the input shaft of the encoder is 1/4 inch. So its press fit in. Then teams zip tie the wires down, which stops the housing from spinning.
Unread 26-07-2015, 17:01
AKA: Ahad Bawany
no team (None)
Okay, I thought you'd simply need to select the 1/4 inch diameter option for the encoders.
When would you use a high cpr vs a low cpr? It seems to me that using a high cpr encoder on a fly wheel might overwhelm the fpga. Any formula to figure out the max possible?
One last question: 971's mentor mentioned their robot featured:
"encoders with index pulses and used a potentiometer with those to resolve the integer number of revolution ambiguity."
How much % of error can one expect simply using an encoder rather than this set up? Is this set up really necessary or simply a practice that, while good for inspiration and education, is a bit overkill?
Thanks for all the help so far!
Unread 26-07-2015, 17:27
High cpr is good for accurate distance, but pulse timing gets pretty jumpy when moving fast. Low cpr allows for smoother pulse timing at high speed. We usually run 256 cpr at 4x for distance, and 6 cpr at 1x, which works great for anything faster then 1000 rpm.
As for distance accuracy, 256 cpr at 4x with a 1.125 inch spool gives an accuracy of 0.003 inches per pulse. That is way more accurate then ever needed, and controlling to that accurate isn't possible.
