Go to Post Remember, everything you do while on the team reflects on your team. Good reputations are difficult to build and easily destroyed. - Daniel_LaFleur [more]
Unread 27-07-2015, 20:34
bstew's Avatar
bstew bstew is online now
FRC #3928 (Team Neutrino)
Team Role: CAD
Rookie Year: 2015
bstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to behold
Re: pic: Duodec-Drive (Octocanum)
The CAD for the module has been available for download on http://www.teamneutrino.org/seasons/...bot/butterfly/. You can see how the module works pretty well from it.
Unread 28-07-2015, 09:46
Ryan_Todd's Avatar
Ryan_Todd Ryan_Todd is offline
ye of little faith
Ryan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond repute
Originally Posted by Aren_Hill View Post
The piston shown is a 1-1/16" bore pancake piston from Automation direct, 1" stroke. It pushes directly down on a 3/8" steel standoff between the two sideplates of the module, and is not connected in any other way.
The module was spring return default to traction mode by a spring (not shown) attached to the small tab you can see behind the omni.
Pop the spring off and pull a single bolt and you could pull the module out.
Mind blown.
I had only ever viewed butterfly & octocanum drives as a curiosity, but now I'll have to reconsider!
Unread 28-07-2015, 11:35
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
Any questions about it just let me know.
-Aren
That is an amazing design! We might be stealing this for next year
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 28-07-2015, 12:00
ParkerF's Avatar
ParkerF ParkerF is offline
Learn it. Teach it. Spread it.
AKA: Parker Francis
FRC #0118
ParkerF has a reputation beyond reputeParkerF has a reputation beyond reputeParkerF has a reputation beyond reputeParkerF has a reputation beyond reputeParkerF has a reputation beyond reputeParkerF has a reputation beyond reputeParkerF has a reputation beyond reputeParkerF has a reputation beyond reputeParkerF has a reputation beyond reputeParkerF has a reputation beyond reputeParkerF has a reputation beyond repute
I would recommend pivoting on the traction wheel unless you have some serious side support. (See Aren's image where the module is snug between the channel.) We had a lot of problems on the 2010 148 drive with this. Your traction wheels will stay put, but the modules will flex sideways under sideloads. We used chains and had issues with them coming off. May not be such a big deal with belts, though.
Team 148 Alumnus - '07-'11
Team 3481 College Mentor - '12-'14
Team 118 Mentor - '17-Present
Unread 28-07-2015, 23:23
Aren_Hill's Avatar
Build Nifty Things
To elaborate on this, the sideplates of this module were .125" thick steel plate, and there were also two pieces of adhesive backed HDPE between the module side plates and the inside tube faces to send the forces straight into the 3x3 tube.
The main reason I chose to pivot on the omni wheel was to keep the CIM hard mounted, rather than swinging with the module (single stage of gearing to the omni wheel).
-Aren
A guy who likes robots.
