Go to Post "automated chaos" nuff said. - Jferrante [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
Unread 28-07-2015, 10:59
Loose Screw's Avatar
Loose Screw Loose Screw is offline
A Loose Screw
AKA: Chris
FTC #5237 (Loose Screws)
Loose Screw is a jewel in the roughLoose Screw is a jewel in the roughLoose Screw is a jewel in the rough
Re: Possibility for 2016 Game
Originally Posted by tindleroot View Post
I see it as a two-way street. FTC and FRC have both incorporated elements of each other. For example, Ring it Up shows obvious analogies to FRC Triple Play (Tic Tac Toe bonuses) and Logomotion (rings on pegs) and FTC Cascade effect brings back the moving goals that were popular in FRC in 2001, 2002, and 2004. Of course, the games have differences, but FTC is not just a testing ground for FRC, FTC also uses elements that have been proven by FRC.
You're right, I forgot about that side. It does work both ways. I just hope that they learn from Bowled Over and always put a height cap on robots. Could you imagine a FRC robot playing a Bowled Over type game? That would be crazy.
