| My love for you never slides around. |
| Thread Tools |
Rating:
Display Modes |
In Need of Banebot Wheels
Does anyone know if they have 3-7/8"x0.8", 1/2" Hex mount, 40A banebot wheels? Or anything close? They are for our new intakes for our Recycle Rush bot.
We have other ideas for wheels (Colsons, Custom wheels lined with polyurethane), but the banebot wheels are ideal. We just want to know what our options are. Last edited by BumblingBuilder : 28-07-2015 at 14:03. Reason: specification |
Re: In Need of Banebot Wheels
I will definitely check our shop
The green mushy ones appear to be in stock right now.
Because Banebots was out of stock we went a different route this year. We 3D printed wheels (~4" OD out of PLA @ 60% infill) and used Polyurethane Rubber Tube as the tread (McMaster 87235K79). Just cut to width and stretch over the wheel. We had lips on either side to retain the tread. These worked fantastic and the wear was nothing compared to Green Banebot wheels (we didn't have Orange to try). Just be sure to clean them in between matches. These collector wheels went through 2 regionals, champs, IRI, R2OC and are perfectly fine. We did replace the tread for IRI but we didn't need to.
You can also do this with Vexpro pulleys as a wheel (kind of hokey, but works).
https://docs.google.com/spreadsheets...NNc/edit#gid=0 It doesn't make a huge amount of sense to use the pulleys as hubs for small OD wheels if you have the ability to hex broach something... but if you don't it's not an awful way to do it (relatively low cost and weight). Quite a few teams this year made wheels with this tread and loved it. Last edited by AdamHeard : 28-07-2015 at 16:27. |
#7
We put it around a chunk of plastic rod we had lying around and cut it on a band saw. Worked very well. But basically wastes the rod (creates nice hockey pucks). You probably could just cut it with a band saw without the rod and be fine.
I'm sure there's a better way. |
#9
During my pit walk at St. Louis this year, I got a chance to talk to a few teams that used similar wheels.
One of the nicer methods of creating these wheels seemed to be to push the tube onto the hub, put the assembly in a lathe, and cut off the excess plastic. If this proves to be unstable, the above idea with putting a plastic piece inside all the way might be better. |
#10
The company that made our wheels put the tube of urethane on a plug in a lathe and cut it with a exacto knife lathe tool.
#11
My old taem used blue McMaster drive rollers for our intake this year. We tested the intake to death, trying almost every traction material and wheel we could get our hands on. At first it seemed like nothing beat orange / blue Banebots, but then when Banebots ran out of stock, we put these McMaster wheels on. These wheels work the same if not slightly better. Trust me, they're worth it. And you'll never have to replace them due to wear!
You may have seen these wheels on frisbee shooters in 2013; I think 341, 2056, 1114, 254, among others all had them. 2056 used one as a shooter wheel in 2012 as well. They're pretty nice. The only catch is you have to make a hub for them, though I've heard you can make a Vex VersaHub work in a pinch. http://www.mcmaster.com/#drive-rollers/=y9865l You'll want PN 2477K36. We used 60A durometer. |
#14
Wheel w/ Tread: Wheel w/o Tread: Vex Versa Wheel w/ tread. This was used on our practice bot since February. Never been changed. The notch at the bottom of the tread is from it rubbing against a bolt before we noticed. We went with 3D printed wheels for weight. Last edited by bigbeezy : 28-07-2015 at 23:17. |
#15
