Go to Post I guess this is where theory vs reality comes into play. - PhilBot [more]
  #31   Spotlight this post!
Unread 17-07-2015, 21:01
jman4747's Avatar
jman4747 jman4747 is online now
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
Re: Stepper Motors
http://www.dtic.mil/get-tr-doc/pdf?AD=ADA577582
Above is a study by the Army Research Laboratory comparing brushed to brushless motors for use in UAV's and land robotics systems. I like it because it talks about commercially available motors and practical concerns such as the fact that for consumer brushless motors the specs an engineer would need like stall torque, free speed, stall current, etc, etc. (what we are used to seeing for dc permanent magnet motors) are rarely if ever provided.
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
  #32   Spotlight this post!
Unread 27-07-2015, 19:40
slomobile slomobile is offline
slomobile is an unknown quantity at this point
Re: Stepper Motors
Reading 2015 R42 Table 4-4, it is legal to power electrical solenoids with the PCM. What is a stepper but 4 solenoids arranged about a steel rotor?
If each coil of a stepper were connected to a solenoid channel, and the channels were activated and deactivated in the right sequence, the stepper would function correctly. It would not be fast or efficient code, but it would work, it would be safe, and as far as I can see, it would be legal. Getting a robot inspector to agree is a completely different matter.
The inherent current limitation of the PCM ensures that unsafe forces will not be developed.
Useful applications of steppers in FRC include camera turrets, gating, and autonomous aiming mechanisms where a device needs to be rotated to multiple positions with a high degree of repeatability. There are some applications where there just isn't room for multiple limit switches or the degree of movement required is so small that it simply cannot be achieved by brushed motors without overshoot.
All the warnings about becoming out of step mentioned earlier in the thread still apply, but a home limit switch can mitigate the effects.
  #33   Spotlight this post!
Unread 27-07-2015, 20:09
Re: Stepper Motors
It would also be useless. See, the limit on electrical solenoid actuators is 10W, 1" stroke, each. Therein lies the problem: converting that 1" stroke into a stepper motor isn't going to be easy... (For that matter, I've only ever seen 1 team that I know for sure used electrical solenoid actuators. 1. And I've been doing this for... well, let's not go into that.)
Meanwhile, the folks who used a servo or three are going to be done already and busy tracking. (And have probably rigged a window motor with PID to act as a really big servo...)
  #34   Spotlight this post!
Unread 28-07-2015, 00:21
JamesTerm's Avatar
JamesTerm JamesTerm is offline
Terminator
AKA: James Killian
FRC #3481 (Bronc Botz)
JamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to behold
Re: Stepper Motors
Originally Posted by Oblarg View Post
Do you think there's any chance we'll ever see steppers on the list of FRC-legal motors?
I don't know much about steppers but I'd like to ask a question... if it were legal, how would it be wired to the roboRIO? What is its voltage and current specs?
One mystery I've been tracking deals with the loss of the Vex 393 being legal, and while I have yet to find the official answer why it was pulled... I'm guessing its electrical needs are not quite a good fit for the roboRIO. I'm still working out the amp draw from the roboRIO vs. the digital side car.
As I recall there were several rules about the wiring that prohibit any special wiring needs to manage the voltage... so for example if I wanted to use the 393 I could either provide a separate 7.2 power source, or wire my own voltage regulator. (these things would be discouraged). So I'm curious how good of a fit these stepper motors would be in terms of wiring.
  #35   Spotlight this post!
Unread 28-07-2015, 01:25
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Re: Stepper Motors
Well if we used standard 1.8 or 0.9 degree NEMA23 steppers like a RepRap with 1.2-1.4A per phase at around 3.5 to 4.2Ohms.
We could use the same Allegro Semiconductor A4988 drivers as the RepRap RAMPS 1.4.
That would get a STEP+DIR interface to the stepper motor for a 5V TTL signal level and take the motor power from either the battery directly or some DC/DC conversion.
An Arduino can obviously control this with a RAMPS 1.4 board on a RepRap 3D printer with several steppers per MEGA2560 so there' s no reason someone couldn't hack up either an Atmel based stepper controller or just use the digital I/O.
The carrier board based A4988 drivers can often be found for the $4-$8 range each.
If you look around you can find a cheap Arduino in the $5 range.
Even if you forked over for the whole RAMPS 1.4 board with the Arduino you can get that whole package for around $75 from SainSmart.
You may also want to get some small aluminum heatsinks for the A4988 they can overheat near stall.
So one could create some custom RAMPS 1.4+Arduino MEGA2560 firmware and have a bunch of these steppers running from a RoboRio with that as a coprocessor drawing power from the robot PDP breakers. Seems like $75 + $10-$20 a stepper motor. Cost wise it's easily comparable to cost of a Talon and a CIM or a bunch of hobby servos. Course this has the issue of how to integrate the field safety shutoffs, however I can see quite a few ways to make that work.
Speaking purely as a matter of possible - not as a matter of FRC legal.
  #36   Spotlight this post!
Unread 28-07-2015, 09:27
Re: Stepper Motors
The 2015 list of legal motors includes Electrical solenoid actuators with a specific limited power and a specific limited stroke length. I am absolutely certain that stepper motors are not, nor do they contain, solenoid actuators.
If I were inspecting a robot and found a stepper motor, I would not consider it legal. If a team tried to argue that stepper motors are just solenoids in a certain arrangement, I would tell them they are entitled to present their case to the Lead Robot Inspector.
If I were the LRI and a team tried to make that case to me, I would give them a yellow card for egregious attempted lawyering.
  #37   Spotlight this post!
Unread 28-07-2015, 11:04
jman4747's Avatar
AKA: Josh
Team Role: CAD
Re: Stepper Motors
So I think, other than the brushless discution, we are somwhat off track. I Think the main point of the OP was to find resions why stepper motors could not be legalized but this has become more of a discussion on whether or not they are useful to a particular team. I think thay can and shold be allowed with very simple restrictions that are easy to verify. It won't hurt you if you don't touch them.
#banthebag
#RIBMEATS
#1620
  #38   Spotlight this post!
Unread 28-07-2015, 12:21
techhelpbb's Avatar
Re: Stepper Motors
I think someone would have to demonstrate to FIRST headquarters that: your stepper motor control was cost effective, open-source and meets the safety requirements to get started down this path.
As noted previously then they might need to donate a bunch to FIRST to evaluate.
Good news is thanks to RepRap printers there is a big DIY community for NEMA17/23 steppers and the parts needed to control them. Thing is the end product will probably have to be FIRST specific or have FIRST specific options.
So yes someone could drive this change: but there's some costs and some lobbying involved that will probably take this into late next year at the very earliest - if they even agree to consider it.
Also I've picked that NEMA size stepper for a better reason than merely the availability of cheap control parts.
You want steppers that will work within reason at the battery voltages of the robot.
CNC controls for steppers often use more than 24V even more than 48V for the stepper power supplies.
So realistically we should consider the practical limitations: FIRST is not likely to start letting you add whole batteries.
  #39   Spotlight this post!
Unread 28-07-2015, 13:24
jman4747's Avatar
AKA: Josh
Team Role: CAD
Re: Stepper Motors
That assumes we use the same rule that only specific controllers are allowed. A 12v to 24v step up converter isn't necessarily all that hard to find. I Don't however know about the required current capacity for a typical size stepper you could likely see on an FRC robot.
#banthebag
#RIBMEATS
#1620
  #40   Spotlight this post!
Unread 28-07-2015, 14:02
techhelpbb's Avatar
Re: Stepper Motors
How else would you implement the field safety features such that the stepper can not be moved while not enabled?
Yes you can certainly boost voltage like FIRST did with the cRIO.
Something like this would do it.
Course at 24V@3A you are just scratching the surface of the power requirements for a single stepper.
As an inductive load your switching DC-DC converter will need to be slightly overrated.
A A4988 for example can handle 1A coils with minimal heatsinking, 2A if you fully heatsink and force air cool. So if your RAMPS 1.4 PCB is configured like a Prusa I3 then you have: X, Y, Z split to 2 stepper drivers, extruder single stepper. Assuming the coils are all in parallel it's easy to pull 1.4A or more to each stepper while moving full steps if the current limit set on the A4988 allows it. It is quite possible the maximum torque will limit below 200oz-in at the lowest RPM, more over even below 100oz-in with some stepping motors. This assumes of course that the voltage of the stepper is such that the robot battery voltage is sufficient to move it the full stepping and micro-stepping modes. So the voltage of the stepping motor should be below 12V to come off a FIRST style battery. (This is safe because this A4988 driver is a current limited chopper driver: set the current limit wrong smoke the stepper motor AKA safe unless you do it wrong.)
To put this in perspective: a <12V NEMA23 stepper with this A4988 on a 12V battery is going to be about the force of a general case hobby servo.
A RepRap generally needs a fraction of this force to move the mechanics if built properly.
  #41   Spotlight this post!
Unread 28-07-2015, 14:33
Andy A. Andy A. is offline
Getting old
FRC #0095
Re: Stepper Motors
I'd like to see steppers included in the rule set. Surely there are cases where they'd be useful, and it'd be a neat way to introduce students to a different sort of motor and control scheme.
I recall a turret on a robot from a few years ago that'd have been a perfect candidate for a stepper, as lost steps seem unlikely and the speed/torque requirements strike me as having been within reason for the smaller NEMA size motors out there. It's been a while, but I'm pretty sure it'd have worked nicely. A closed loop brushed motor achieves the same results but in this case the stepper strikes me as the more elegant answer.
As a practical matter, I suspect it'd take a motor/controller combination that can achieve the same sort of holding torque that a window motor currently produces, and which is also reasonably compatible with FRC's electrical and cost limitations. I have no idea if such a thing exists, but it's probably out there.
Whether the benefit, which is mostly the novelty factor, justify the headache of sourcing them and the rule changes is another story.
  #42   Spotlight this post!
Unread 28-07-2015, 14:54
techhelpbb's Avatar
Re: Stepper Motors
Oh you want more power eh:
Same idea with external power MOSFETS
On a PCB
In fairness many window motors use a worm drive.
So the holding torque is really about how strong the gearing is.
As long as the stepper has the torque required to turn the worm gear.
Another way is to use a something like a dog gear to lock the mechanism at the stop point.
The advantage with the dog is that you don't inherit the high worm gear ratio because as steppers move faster they operate with lower torque.
Then again could just use a clutch.
