Go to Post Uhh... we were supposed to be building a robot? *looks at giant wooden Trojan Rabbit in the corner that was built instead for the past 6 weeks* Whoops... - Adam Richards [more]
Unread 28-07-2015, 13:40
BumblingBuilder's Avatar
BumblingBuilder BumblingBuilder is offline
Red is fast
AKA: Matthew
FRC #2169 (KING TeC)
BumblingBuilder will become famous soon enough
In Need of Banebot Wheels
Does anyone know if they have 3-7/8"x0.8", 1/2" Hex mount, 40A banebot wheels? Or anything close? They are for our new intakes for our Recycle Rush bot.
We have other ideas for wheels (Colsons, Custom wheels lined with polyurethane), but the banebot wheels are ideal. We just want to know what our options are.
Unread 28-07-2015, 15:08
CJ_Elliott's Avatar
CJ_Elliott CJ_Elliott is offline
FRC #2502 (Talon Robotics)
CJ_Elliott is a glorious beacon of lightCJ_Elliott is a glorious beacon of lightCJ_Elliott is a glorious beacon of lightCJ_Elliott is a glorious beacon of lightCJ_Elliott is a glorious beacon of lightCJ_Elliott is a glorious beacon of light
Re: In Need of Banebot Wheels
I will definitely check our shop
Unread 28-07-2015, 15:40
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
The green mushy ones appear to be in stock right now.
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 28-07-2015, 16:03
bigbeezy's Avatar
bigbeezy bigbeezy is offline
AKA: Bryan
FRC #2338 (Gear it Forward)
bigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to behold
Send a message via AIM to bigbeezy
Because Banebots was out of stock we went a different route this year. We 3D printed wheels (~4" OD out of PLA @ 60% infill) and used Polyurethane Rubber Tube as the tread (McMaster 87235K79). Just cut to width and stretch over the wheel. We had lips on either side to retain the tread. These worked fantastic and the wear was nothing compared to Green Banebot wheels (we didn't have Orange to try). Just be sure to clean them in between matches. These collector wheels went through 2 regionals, champs, IRI, R2OC and are perfectly fine. We did replace the tread for IRI but we didn't need to.
Team 1592 Bionic Tigers -- Driver 2005-2008
Winner - Florida Regional 2005
Finalist - Newton Division 2007
Winner - Colorado Regional 2008
Florida State University - BS Mechanical Engineering
Team 2338 Gear it Forward -- Mentor/Drive Coach 2013-Present
Winner - Wisconsin Regional 2013
Chairman's Award - Midwest Regional 2015
Winner - Archimedes Sub-Division 2015
Chairman's Award - Midwest Regional 2016
Unread 28-07-2015, 16:06
mwmac's Avatar
mwmac mwmac is offline
JWBWIFWWWADD
AKA: Mike MacLean
FRC #2122 (Team Tators)
mwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond repute
Sounds like a great idea!
2016 Carson W 2122, 2052, 3538, 41, AZ North W 2122, 125, 498, MQA, Idaho F 2122, 3250, 3513, MQA, CCC W 2122, 9122, 6174, ICA
2015 Tesla SF IDA 2122, 3360, 2960, 1311 IRI SF 2338, 2122, 107, 234 UT F 2122, 3230, 3405, EEA, WFFA, AZ West W 2122, 3309, 5059, ICA
2014 Galileo QF 1717, 2122, 3683, 193 UT W 2122, 2996, 3191, ICA, CCC W 1678, 2122, 9073, ICA
2013 CalGames W 2122, 1678, 4171, Judges Award
2012 Newton QF 2122, 610, 488 Spokane W 2122, 1983, 4082, EEA
2011 Newton SF 1730, 2122, 11 IRI F 3138, 16, 2122, 1730, UT W 2122, 399, 3239, MQA, Seattle F 2122, 488, 2850, MQA
2010 Galileo SF 78, 51, 2122 UT W 1696, 2122, 3405, IDA, Sacramento F 2122, 2035, 1834, IDA,
2009 Sacramento F 2144, 692, 115, 2122, MQA
2008 Newton Sacramento W 2122, 1662, 115, CA
2007 PNW Regional Highest Rookie Seed
"Enjoying traveling to more distant events" since 2007
Unread 28-07-2015, 16:25
AdamHeard's Avatar
Lead Mentor
You can also do this with Vexpro pulleys as a wheel (kind of hokey, but works).
https://docs.google.com/spreadsheets...NNc/edit#gid=0
It doesn't make a huge amount of sense to use the pulleys as hubs for small OD wheels if you have the ability to hex broach something... but if you don't it's not an awful way to do it (relatively low cost and weight).
Quite a few teams this year made wheels with this tread and loved it.
Unread 28-07-2015, 18:32
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Anyone have any tips for cutting the polyurethane cleanly?
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 28-07-2015, 18:39
bigbeezy's Avatar
AKA: Bryan
We put it around a chunk of plastic rod we had lying around and cut it on a band saw. Worked very well. But basically wastes the rod (creates nice hockey pucks). You probably could just cut it with a band saw without the rod and be fine.
I'm sure there's a better way.
Unread 28-07-2015, 19:18
TheHolyHades1 TheHolyHades1 is offline
TheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the rough
During my pit walk at St. Louis this year, I got a chance to talk to a few teams that used similar wheels.
One of the nicer methods of creating these wheels seemed to be to push the tube onto the hub, put the assembly in a lathe, and cut off the excess plastic. If this proves to be unstable, the above idea with putting a plastic piece inside all the way might be better.
Unread 28-07-2015, 19:42
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
The company that made our wheels put the tube of urethane on a plug in a lathe and cut it with a exacto knife lathe tool.
2016: FRC 865 Mentor
Unread 28-07-2015, 19:58
AdamHeard's Avatar
Lead Mentor
This is what we did at real low speed with a razor blade clamped to the tool post.
Unread 28-07-2015, 20:40
mlantry mlantry is offline
I'm back
AKA: Matthew Lantry
mlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud of
You wouldn't happen to have any images of these wheels would you? Also some of the wheels without tread attached
Matthew Lantry
Team 4475 2014-present
-College Mentor 2014-????
Team 1676- 2011-2014
-Mechanical 2011-2014, Subteam leader 2013-2014
-Robot Operator 2014
George G. White FLL mentor 2011-2014
“Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute.”
Unread 28-07-2015, 21:51
Chris is me's Avatar
AKA: Pinecone
My old taem used blue McMaster drive rollers for our intake this year. We tested the intake to death, trying almost every traction material and wheel we could get our hands on. At first it seemed like nothing beat orange / blue Banebots, but then when Banebots ran out of stock, we put these McMaster wheels on. These wheels work the same if not slightly better. Trust me, they're worth it. And you'll never have to replace them due to wear!
You may have seen these wheels on frisbee shooters in 2013; I think 341, 2056, 1114, 254, among others all had them. 2056 used one as a shooter wheel in 2012 as well. They're pretty nice. The only catch is you have to make a hub for them, though I've heard you can make a Vex VersaHub work in a pinch.
http://www.mcmaster.com/#drive-rollers/=y9865l
You'll want PN 2477K36. We used 60A durometer.
Unread 28-07-2015, 23:09
bigbeezy's Avatar
AKA: Bryan
Collector:
Wheel w/ Tread:
Wheel w/o Tread:
Vex Versa Wheel w/ tread. This was used on our practice bot since February. Never been changed. The notch at the bottom of the tread is from it rubbing against a bolt before we noticed. We went with 3D printed wheels for weight.
Unread 28-07-2015, 23:17
bigbeezy's Avatar
AKA: Bryan
I'm curious as to the difference between these and the ones similar to what we used (McMaster 87235K79). From a cost comparison at same width wheels you are talking ~$8.30/wheel vs ~$30/wheel. For our collector we used the 40A.
