Go to Post Blue shirts are ALWAYS watching. And they have spies everywhere. Always be on your best behavior, and be polite to every volunteer at the event. - Andrew Schreiber [more]
Unread 28-07-2015, 20:40
mlantry mlantry is offline
I'm back
AKA: Matthew Lantry
mlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud of
Re: In Need of Banebot Wheels
Originally Posted by bigbeezy View Post
Because Banebots was out of stock we went a different route this year. We 3D printed wheels (~4" OD out of PLA @ 60% infill) and used Polyurethane Rubber Tube as the tread (McMaster 87235K79). Just cut to width and stretch over the wheel. We had lips on either side to retain the tread. These worked fantastic and the wear was nothing compared to Green Banebot wheels (we didn't have Orange to try). Just be sure to clean them in between matches. These collector wheels went through 2 regionals, champs, IRI, R2OC and are perfectly fine. We did replace the tread for IRI but we didn't need to.
You wouldn't happen to have any images of these wheels would you? Also some of the wheels without tread attached
Matthew Lantry
Team 4475 2014-present
-College Mentor 2014-????
Team 1676- 2011-2014
-Mechanical 2011-2014, Subteam leader 2013-2014
-Robot Operator 2014
George G. White FLL mentor 2011-2014
“Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute.”
