Go to Post How else can I get my polar bear sized tub of Lard? - niklas674 [more]
Unread 29-07-2015, 15:12
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: Detecting if the code runs from the PC or the RoboRIO
Originally Posted by Jonathan L. View Post
I have not tested this with a FRC robot yet but I think this is what you're looking for. See this video at 18 min 15 sec and 21 min 30 sec. http://www.ni.com/webcast/3798/en/
The Conditional Disable Structure...
Unfortunately I do not think the conditional disable structure will work the way that you want without some extra effort.
The only time RUN_TIME_ENGINE is FALSE will be if you are running the code on your host machine. This works if you are using the simulator vs the actual robot, but once you run it on the robot as you describe it will be TRUE. Target_Type and OS will give you the same issue.
You can create a conditional that is project wide, and manually change it when you build, but that is tedious and more importantly is error prone.
You may be able to play around with the build specification, maybe with the pre/post build actions combined with the project wide build specification, but this is not something I have never tried.
You may be better of with the suggestion from Ari423 unless you have a good reason to prevent the code block from compiling in the first place.
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 29-07-2015, 15:30
If you are asking about simulated versus running on the roboRIO, the Conditional Disable Structure is what you are looking for. An example of how to use it is shown in this VI vi.lib\Rock Robotics\SystemInterfaces\NetworkCommunication\Net Comm_UnloadCPPStartupProgram.vi
If you want to know if a debugging host is connected, I believe you want to use a Property Node to read the App.UserInterfaceAvailable property. Read the help and I think you will see that it does what you want. If not, please explain more of what you are looking for.
Greg McKaskle
Unread 29-07-2015, 15:34
Ari423's Avatar
Ari423 Ari423 is online now
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
I just had an idea. When you get the file path of Robot Main in Robot Main, if it is built and running in the robot project the second to last string in the file path will be projectName.exe, whereas if you were running it in debug mode (manually running Robot Main) the second to last string in the file path will be the folder the project is in. You should be able to get the file path, strip it twice, and search the second stripped string for ".exe". If you are running a build the index will be greater than 0 (it exists somewhere in the string). If it is running in debug mode, the index will be -1 (search string isn't in source string). You can then save this bool as a global, carry it into teleop and/or periodic, or do whatever you want with it. Let me know if this works.
EDIT: I think this is what you are looking for without using any complicated property nodes. There may be other ways to do the same thing using property nodes or otherwise, and you should feel free to use whichever you feel is easier. My original suggestion about removing this code from the final project still stands.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
