#31
Re: General Motor Rules
I'm not trying to get one specific motor legalized and this thread isn't about stepper motors or brushless motors. The point is to make use of any comparable motors regardless of P/N. It has nothing to do with trying to obtain a marginal increase in power form an obscure motor. I am asking for the freedom to source and use similar motors at will. This has nothing to do with changing the allowed number of motors on a robot/total allowed power.
We already see teams short, stall, smoke, our current selection. We have snap action and main breakers, the motor will only have a 12V power source, and it's an 18ah lead acid battery. Thus regardless of the motor specs the electrical system will not allow more power output or current draw and won't pose more of a threat to the operators. If teams already burn out BB 550's what is the problem burning out a 550(ish) motor? As for inspection, relax the restriction and base it off of simple criteria (like Adams idea). Don't change anything in the control or electrical system. You could even limit the motors to the 20 amp circuits like the custom circuit rules if that is a concern. |
#32
If anything, I would say allow motors by brand, and specifically allow a few different brands. That way the teams that needed could walk into their local hobby store and get some RC car motors, or a place like AM could sell specific ones that meet teams needs, such as the current 775 and 550. |
#35
#36
I love the simplicity of what you've proposed, but for me to get behind the issue, FIRST would need to identify a vendor which has a steady supply of motors in at least 75th percentile (perhaps much higher depending on the marginal power increase available around the 75th percentile) of power available in the form factor. Last edited by Karthik : 30-07-2015 at 14:32. |
#37
Tangentially related, we use the regular tetrix chargers like noobs in 2011... |
#38
No team has an advantage in finding a better motor. Inspectors now only have 4 motors to identify. Simpler on teams, simpler on inspectors. No serious advantage to teams who can find a slightly better motor. All motors have a wide variety of COTS interface solutions (interfacing with the old FP gearboxes sucked) The only downside is I'd like to see a lower power motor added but we could open up servo limits (say 20W) and that would fill that need. Course, I don't understand why we need MORE variety in motors. [1] I picked a motor that's widely available from a supplier familiar with FIRST ordering and timelines. |
#39
Oh well, it was [not] worth a shot. While were at it how about going to 24V?
#41
By going to 24V you obsolete every current FRC motor.
#42
And a lot of the electrical system.
#43
No worries you just run all the appendages off of one large motor. The tank drive would use dog gears to reverse and disconnect power on each side and belts and shafts transmit torque to other parts of the robot. It'd work like a early factory or mill with one big steam engine in the basement and line shafts for power transmission.
