Go to Post None. Ours is anorexic at the moment. Lets see if the building people can come up with a simple tetra-knockdown mechanism. - Fixen [more]
Unread 29-07-2015, 10:02
mlantry mlantry is offline
I'm back
AKA: Matthew Lantry
mlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud of
Re: In Need of Banebot Wheels
Originally Posted by bigbeezy View Post
Collector:
Attachment 19232
Wheel w/ Tread:
Attachment 19233
Wheel w/o Tread:
Attachment 19234
Vex Versa Wheel w/ tread. This was used on our practice bot since February. Never been changed. The notch at the bottom of the tread is from it rubbing against a bolt before we noticed. We went with 3D printed wheels for weight.
Attachment 19235
So did you make a tire essentially with the none adhesive belt. Did you melt the belt together?
Matthew Lantry
Team 4475 2014-present
-College Mentor 2014-????
Team 1676- 2011-2014
-Mechanical 2011-2014, Subteam leader 2013-2014
-Robot Operator 2014
George G. White FLL mentor 2011-2014
“Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute.”
Unread 29-07-2015, 13:03
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
The tire seems to be tube and not a strip. Same polyurethane tube a handful of teams used this year.
R.C.
MadTown Robotics Team 1323
Unread 29-07-2015, 13:08
bigbeezy's Avatar
bigbeezy bigbeezy is offline
AKA: Bryan
FRC #2338 (Gear it Forward)
bigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to behold
Send a message via AIM to bigbeezy
It is a rubber tube. Comes 4" OD x 3" ID (McMaster has numerous sizes and lengths). We cut 1" sections from the 6" long tube and stretched it onto the wheel. No adhesive, screws, rivets, etc. needed.
Team 1592 Bionic Tigers -- Driver 2005-2008
Winner - Florida Regional 2005
Finalist - Newton Division 2007
Winner - Colorado Regional 2008
Florida State University - BS Mechanical Engineering
Team 2338 Gear it Forward -- Mentor/Drive Coach 2013-Present
Winner - Wisconsin Regional 2013
Chairman's Award - Midwest Regional 2015
Winner - Archimedes Sub-Division 2015
Chairman's Award - Midwest Regional 2016
Unread 29-07-2015, 15:48
Happy Birthday! Travis Hoffman Travis Hoffman is offline
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Because Banebots was out of stock we went a different route this year. We 3D printed wheels (~4" OD out of PLA @ 60% infill) and used Polyurethane Rubber Tube as the tread (McMaster 87235K79). Just cut to width and stretch over the wheel. We had lips on either side to retain the tread. These worked fantastic and the wear was nothing compared to Green Banebot wheels (we didn't have Orange to try). Just be sure to clean them in between matches. These collector wheels went through 2 regionals, champs, IRI, R2OC and are perfectly fine. We did replace the tread for IRI but we didn't need to.
We used the same polyurethane material, but for hubs, we lathed the tread off of old Banebots 3-7/8" wheels and attached with adhesive and screws. We'd do this again, in a pinch. We recycled, in a rush.
Unread 29-07-2015, 16:47
sportzkrazzy's Avatar
sportzkrazzy sportzkrazzy is offline
AKA: Zac
FRC #1592 (Bionic tigers and 801 Horse power)
sportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant future
Send a message via AIM to sportzkrazzy
The polyurethane material is definitely the way to go. We tested pretty much everything out there and that was the most durable, highest traction materiel we could find for manipulating both totes and rcs. The trick is keeping them clean. Wiping them down in between in match does the trick. The best thing about it is that you can get for any much any size intake roller you need maxing out at 4 inches. We just stretched it over a 4 inch andymark performance wheel because that's what we had laying around at the shop. It required no adhesives just relied on the friction between the materiel and the hub to hold it and it worked great. The only thing we did was machine it down drastically to save weight. 179 Used them as well at IRI and they 3d printed plastic hubs for them. Originally they tried to make them out of abs but the hubs where not holding up do to the loads and impacts however after they switched to pla they held up great. Maybe someone from 179 can provide a little more incite on printing methods ie infill, wall thickness,and print direction.
Unread 30-07-2015, 09:32
topgun's Avatar
topgun topgun is offline
FRC #2846 (FireBears)
topgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant future
The ingenuity and different thinking shown in this thread is inspiring, and will make my life easier during build season.
I always find these kind of threads extremely useful! Keep the ideas rolling.
-T
Unread 30-07-2015, 11:50
BumblingBuilder's Avatar
BumblingBuilder BumblingBuilder is offline
Red is fast
AKA: Matthew
FRC #2169 (KING TeC)
BumblingBuilder will become famous soon enough
Yeah we are thinking about doing this if other options are unavailable. Thanks for the info!
Unread 30-07-2015, 12:02
Red is fast
AKA: Matthew
Yeah, our intakes were the weakest part of our robot during the season so they really need a redesign. Thanks for all the ideas you all proposed! I have no one from my team to consult right now, but I feel convinced about the polyurethane method.
Unread 30-07-2015, 14:00
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
Just throwing this question out there - since I have no experience with these at all...but how would Colson wheels compare? It seems a much more affordable option than the expensive polyurethane material from McM.
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 30-07-2015, 14:03
Knufire Knufire is offline
I would imagine Colson wheels have a significantly lower CoF on a tote or can than a softer polyurethane compound.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 30-07-2015, 14:05
AdamHeard's Avatar
Lead Mentor
Agreed. The polyurethane has a non-sticky tackiness that grips things very well which other treads don't seem to. The 2010 balls, 2013 disks, 2015 bins, etc...
All said and done a mcmaster based polyurethane custom wheel is about 2-3 times the cots of a banebots wheel, but will last far far longer and performs great deal better. The relatively thick tread has some give/compression which helps as well.
Colsons are slightly cheaper, would last presumably as long, but not perform nearly as well (they're really a different kind of tread with different design constraints).
Unread 30-07-2015, 14:14
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
We used similar material on our shooter wheels in 2014. However we used strips instead of the tube. For hubs, we just used standard VEXpro 4" traction wheels, that way we could easily integrate them into our robot using the Versa hubs and hex shaft, without having to make any custom parts.
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 30-07-2015, 15:12
llamadon's Avatar
llamadon llamadon is offline
Gold pants swag
AKA: Quinn
llamadon is just really nicellamadon is just really nicellamadon is just really nicellamadon is just really nice
We had thought about using the adhesive backed strips of the poly-urethane from McMaster that has been mentioned in this thread. Is this what 1114 used on their shooter wheels? Or were the strips attached by other methods? Such as rivets or bolts?
Unread 30-07-2015, 15:22
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
Would anyone happen to know how much larger/smaller you want the tubing to be compared to whatever you slide them onto? From what I've heard, you want something slightly smaller than the diameter of what you're going to slide onto, and you need to inflate it slightly so it slides onto it.
Unread 30-07-2015, 15:25
We did not use the adhesive backed versions; we riveted the material on instead.
