Go to Post Well, it worked in inventor . . . - Chris Fultz [more]
Unread 30-07-2015, 00:53
rainbowbear998's Avatar
rainbowbear998 rainbowbear998 is offline
FRC #4739 (Thunderbolts Robotics)
rainbowbear998 is an unknown quantity at this point
Driver Assistance Used This Season?
As FTC is coming up, my team and I have been discussing methods of driver assistance that we could use for it. I've been wondering, what did other teams use for driver assistance this FRC season or even in past seasons?
2016 Dean's List Semi-Finalist
Captain, FRC Team 4739
Unread 30-07-2015, 07:38
Loose Screw's Avatar
Loose Screw Loose Screw is offline
A Loose Screw
AKA: Chris
FTC #5237 (Loose Screws)
Loose Screw is a jewel in the roughLoose Screw is a jewel in the roughLoose Screw is a jewel in the rough
Re: Driver Assistance Used This Season?
Originally Posted by rainbowbear998 View Post
As FTC is coming up, my team and I have been discussing methods of driver assistance that we could use for it. I've been wondering, what did other teams use for driver assistance this season or even in past seasons?
One thing I would reccommend is using LED lights. Not just because they are cool, but because you can use them along side a manipulator to assure that it's in the right position.
For example, in Cascade Effect we had a Rolling Goal latch that would hook onto the Rolling Goal to drag it behind us. The only problem was that it would only work in one orientation of the goal. It was also on the back of our robot, and the goals were on the other side of the field when we grabbed them. This made a successful latch very hard to achieve, and usually wasted time. We could have added a limit switch wired to LEDs that would light up when it was in the correct position, thus eliminating all guesswork.
My FRC team that I graduated from has used this setup for the last few years. They had limit switches on their catapult to make sure the ball was in the correct position, and limit switches in their intake to make sure the totes would stack neatly on top of each other.
I would highly recommend using LEDs and limit switches to eliminate guesswork on your drivers' behalf. I know my team has been wanting LEDs for a while now, and this is a practical way to use them.
Unread 30-07-2015, 14:47
MikLast's Avatar
MikLast MikLast is offline
CAO/Drive Coach
AKA: Mikal Dieatrick
FRC #4513 (Circuit Breakers)
MikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond repute
While this isint exactly FTC related, in this years FRC competition, Recycle Rush, our forklift mechanism used limit switches to gauge when we had a hold of the totes, and we were able to manipulate the robot to quickly get the best hold he got with the totes. (basically we would close the forks, and if one fork hit the robot the robot would jerk slightly to a side to close the gap, making it easier on us to grab the totes and stack.) We happened to win two innovation in control awards for this, which was a happy surprise.
Check out the FRC Discord!
2014: programmer, scout
2015: programmer, admin, drive team
Innovation in control award, WVHS district event
Innovation in control award, CWU district event
finalist, PNW district championship
2016: CAO, Drive team.
Excellence In Engineering awad, WVHS District event
Unread 01-08-2015, 22:53
EDesbiens's Avatar
EDesbiens EDesbiens is offline
Passionate crackpot
AKA: Étienne Desbiens
FRC #5859 (i)
EDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of light
This year we added a scheme of the robot in the driver station with lights representing the switches to help during testing... We also added a BIG status light to tell if the robot is in error mode or not... Also, for the first time, we had about 10 autonomous modes... So, to help through the selection of the good mode we created an interface where we could locate each of the possible starting locations on a map of the field, an indicator of the number of points produced and a long description of each action made by the robot...
Lisa: Players play and managers manage.
Ralph: Do alligators alligate?
Unread 02-08-2015, 09:59
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
We haven't used this (just thought of it yesterday). Some game controllers have "rumble" vibrators. These could be used for feedback.
Unread 02-08-2015, 10:11
EDesbiens's Avatar
Passionate crackpot
FRC #5859 (i)
We used that and if you put more then one fonction connected to the vibration, you can't really know which triggered it... Even if you can change the power of the vibration emited...
Unread 07-08-2015, 19:46
Dhill098 Dhill098 is offline
AKA: Damian
FRC #2383 (Ninjineers)
Team Role: Driver
Dhill098 is a splendid one to beholdDhill098 is a splendid one to beholdDhill098 is a splendid one to beholdDhill098 is a splendid one to beholdDhill098 is a splendid one to beholdDhill098 is a splendid one to beholdDhill098 is a splendid one to beholdDhill098 is a splendid one to behold
This year with used PS3 controllers. The driver was notified through rumble that 10 seconds were left in the match so he would know to score the current stack. I was the operator this year, and our robots mechanisms and stacker are completely pneumatic. The operator controller rumbled when our tanks fell below 60 PSI.
Unread 07-08-2015, 20:25
Jared Russell's Avatar
Taking a year (mostly) off
I have to admit that making your controller rumble whenever the compressor is running makes some amount of sense...
Now we need to find a USB heat plate so the operator can check the PDP temperature during the match.
Unread 07-08-2015, 20:41
Abhishek R Abhishek R is offline
FRC #0624
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
That's so cool.
Like others said, we also used LEDs for driver feedback. They indicated whether the stack and can were secure as well as indicating whether the robot was in automatic or manual stacking mode. We also had a gyro-assisted drive which made movements feel more precise (to me at least).
Automation always makes an operator's life easier as well. At Dallas, we basically had a shift key on the operator gamepad because he had about 2.5 layers of commands but only one of each button. By the time TRI came around he was only really pushing 5 or so buttons (3 for stacking, 2 for intake).
2012 - 2015 : 624 CRyptonite
Team Website
Unread 07-08-2015, 20:43
Lemon's Avatar
Lemon Lemon is offline
Builder of Robots
AKA: Andrey (Gooby)
Team Role: Electrical
Lemon is an unknown quantity at this point
Well for us the compressor was almost always running. We had a pressure transducer trigger a rumble when PSI dropped bellow 60 more so the operator would be aware of the degradation in pneumatics performance from then on and could adjust his response accordingly.
Unread 07-08-2015, 22:42
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
We actually helped with getting the rumble stuff into the code for this year with the beta feedback. It was actually a really funny conversation. We filed a bug report to get them to add it and were told it wasn't a necessary feature to start with. The other mentor helping with the testing immediately responding and told them we needed it as a usability enhancement for our blind driver. Good times.
Unread 10-08-2015, 23:45
Lij2015's Avatar
Lij2015 Lij2015 is offline
I like turtles
AKA: Elijah Steele
FRC #2363 (Triple Helix)
Lij2015 has a spectacular aura aboutLij2015 has a spectacular aura about
Send a message via MSN to Lij2015
On our 2014 robot we used green LED's that lit up when we had enough pressure to shoot(50 psi we found out by the end of the year) and on 1023's robot this year they had green LED's that lit up I think when the tote was situated.
Also you can buy a pressure gauge reader type set up and set it to display to a labview or smartdashboard.
But for physical things on the robot, LED's that indicate things are the way to go
Alumni turned volunteer!
2016 Chesapeake District volunteer, Scorekeeper/Game announcer.
Team 2363 Proud Alumni, Programmer/Driver 2013, 2014, 2015(Captain)
2016 Northern Virginia Winners (1418 and 2421)
2016 Hampton Roads Finalists(1885 and 5954)
2015 Chesapeake Regional Winners(1690 and 4050)
2015 Virginia Regional Winners(384 and 1610)
2014 Chesapeake Regional Winners(1629 and 623)
2013 Virginia Regional Finalists (3015 and 2053)
Unread 11-08-2015, 00:28
1197 didn't bother with the whole "assist the driver" routine...
...Unless you count our habit of acquiring totes from an HP ramp, lining 'em up for a stack, and getting them stacked and ready for another tote to land underneath with minimal (if any) driver input as assistance, that is! We used an automated loading sequence, and our intake was designed to align totes for a nice easy pickup. I want to say fully automatic stacking once the driver was in position, and ideally we had a can in the top claw.
