Go to Post I've be addicted for 15 years. Tried to quit but failed. - Gdeaver [more]
  #31   Spotlight this post!
Unread 30-07-2015, 16:09
sportzkrazzy's Avatar
sportzkrazzy sportzkrazzy is offline
AKA: Zac
FRC #1592 (Bionic tigers and 801 Horse power)
sportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant future
Send a message via AIM to sportzkrazzy
Re: In Need of Banebot Wheels
Originally Posted by Karthik View Post
We did not use the adhesive backed versions; we riveted the material on instead.
We tried the adhesive backed versions on manipulators in the past but even after giving it plenty of time to cure it did not want to stay on while under load. We tried using a couple of fastening methods as well but it would usually end up tearing out when under load. This was using strips that where 1 inch wide and with a thickness of 3/8ths of an inch. How wide were your strips and how did you fasten them? How often? Any issues with it tearing out?
  #32   Spotlight this post!
Unread 30-07-2015, 16:13
AdamHeard's Avatar
Lead Mentor
About what rpm were you spinning at?
  #33   Spotlight this post!
Unread 30-07-2015, 16:17
Professional Stat Padder
5254 used colsons for their collectors the entire year, and with the modifications made for IRI copying 1114's collector geometry, they were extremely effective at intaking totes at near any angle.
I'm a firm believer that most of the time the small improvements you make in material choice to solve problems might be better solved much of the time by a geometry change. Incrementally improving a middling design can be good, but often scrapping the middling design and taking a different approach can often be more effective.
(2015-Present)
  #34   Spotlight this post!
Unread 30-07-2015, 16:26
AKA: Zac
1592 completely agrees. But material choices is the next thing down the line on a list of things that can improve the functionality and use life of subsystems on your robot.
  #35   Spotlight this post!
Unread 30-07-2015, 19:18
mlantry mlantry is offline
I'm back
AKA: Matthew Lantry
mlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud of
Any chance you have the part number of the specific type of polyurethane strip you used.
Matthew Lantry
Team 4475 2014-present
-College Mentor 2014-????
Team 1676- 2011-2014
-Mechanical 2011-2014, Subteam leader 2013-2014
-Robot Operator 2014
George G. White FLL mentor 2011-2014
“Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute.”
  #36   Spotlight this post!
Unread 30-07-2015, 19:30
Knufire Knufire is offline
I believe it's on McMaster as Soborothane (or I'm getting confused with a different part of an 1114 robot)
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
  #37   Spotlight this post!
Unread 30-07-2015, 21:36
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
I do! P/N: 8834K511
http://www.mcmaster.com/#catalog/121/3586/=ya56jq
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
  #38   Spotlight this post!
Unread 30-07-2015, 22:17
mman1506's Avatar
mman1506 mman1506 is online now
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Originally Posted by thatprogrammer View Post
Would anyone happen to know how much larger/smaller you want the tubing to be compared to whatever you slide them onto? From what I've heard, you want something slightly smaller than the diameter of what you're going to slide onto, and you need to inflate it slightly so it slides onto it.
We over sized the diameter of our hubs by about %10. We had no issues with slipping or installation.
Here is a pic of our wheels if anyone is interested https://scontent-lga1-1.xx.fbcdn.net/hphotos-xpa1/t31.0-8/10256793_10155208355065576_3280327124933048631_o.j pg
Urethane is 30A and the hub is resin cast.
2016: FRC 865 Mentor
