Go to Post Calculate everything. You won't need to make speed holes if you figure it all out beforehand and get it taken care of. - Otaku [more]
Unread 30-07-2015, 16:26
sportzkrazzy's Avatar
sportzkrazzy sportzkrazzy is offline
AKA: Zac
FRC #1592 (Bionic tigers and 801 Horse power)
sportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant future
Send a message via AIM to sportzkrazzy
Re: In Need of Banebot Wheels
Originally Posted by Kevin Leonard View Post
5254 used colsons for their collectors the entire year, and with the modifications made for IRI copying 1114's collector geometry, they were extremely effective at intaking totes at near any angle.
I'm a firm believer that most of the time the small improvements you make in material choice to solve problems might be better solved much of the time by a geometry change. Incrementally improving a middling design can be good, but often scrapping the middling design and taking a different approach can often be more effective.
1592 completely agrees. But material choices is the next thing down the line on a list of things that can improve the functionality and use life of subsystems on your robot.
