Go to Post We would expect our bot to be done by Week 5, but usually its about a day or two before shipping and then the ever-famous "all nite programmin' n driva trainin'" is done. - Bharat Nain [more]
Unread 03-08-2015, 10:31
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
fovea1959 will become famous soon enough
Joystick mapping changed between 2014DS and 2015DS in 2014 mode?
we've kept an old laptop around to use as the driver's station for our 2014 robot. that laptop got sick this weekend, so we fired up a 2015 ds, set it to 2014 mode, and things were mostly ok.
we see a half red/ half green comm indicator for the robot, but reading other threads indicates that normal.
it *seems* that the 2015 DS maps the axes on an XBox controller differently than the 2014 DS. Can anyone confirm or deny?
Unread 03-08-2015, 10:45
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Re: Joystick mapping changed between 2014DS and 2015DS in 2014 mode?
The DS should be sending through whatever the laptop is processing.
I'd be curious to know if the new computer was utilizing some sort of special xbox mapping for gaming and sending that to the DS.
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
Unread 03-08-2015, 10:46
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
The mapping differences you might be seeing could be related to the fact that the mappings are all 0 indexed now.
Unread 03-08-2015, 11:41
EDesbiens's Avatar
EDesbiens EDesbiens is offline
Passionate crackpot
AKA: Étienne Desbiens
FRC #5859 (i)
EDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of light
I'm on labview and I get a very different axis mapping... The buttons only changed to accomodate the 0 index but the axis are really weird...
Lisa: Players play and managers manage.
Ralph: Do alligators alligate?
Unread 03-08-2015, 11:45
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
We recently did a similar thing with our 2014 robot, but didn't notice any different mappings. We had the same half red / half green status light and were able to fix it by putting the correct firmware on the cRIO. Only the correct firmware will allow a cRIO to talk to a 2015 DS, so you may want to check that it is up to date.
Unread 03-08-2015, 11:49
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
I can confirm we had an issue like this that we ran into with beta testing. I don't recall exactly what the cause was but it had to do with the 0 indexing and the POV hats being read as different values... at least that is what I remember.
Unread 03-08-2015, 12:23
jkoritzinsky jkoritzinsky is offline
AKA: Jeremy Koritzinsky
FRC #4786 (Nicolet F.E.A.R.)
jkoritzinsky will become famous soon enoughjkoritzinsky will become famous soon enough
The 2014 Driver Station used the outdated DirectInput API to get the inputs for joysticks. The 2015 DS uses XInput. This is the cause of the changes other than the switch to the 0-based axes/buttons.
Nicolet F.E.A.R. (Team 4786) - Aerial Assist - Programming Manager
Nicolet F.E.A.R. (Team 4786) - 2015+ - Junior Mentor
SuperScouter for FRC Developer
Unread 03-08-2015, 19:43
Jonathan L. Jonathan L. is offline
Programmer alumnus, mentor, and CSA
FRC #1094 (Channel Cats)
Jonathan L. is a jewel in the roughJonathan L. is a jewel in the roughJonathan L. is a jewel in the roughJonathan L. is a jewel in the rough
One side of the Communication indicator shows the status of the TCP connection (used for sporadic data like errors, Usage Reporting and PDP Logs), the other half shows the UDP connection (for the main robot control and status). You might want to check your firewall settings.
Unread 04-08-2015, 13:42
fovea1959's Avatar
AKA: Doug Wegscheid
What is the correct firmware (and how do I check what's running on the cRIO)?
Unread 04-08-2015, 13:43
fovea1959's Avatar
AKA: Doug Wegscheid
Is this the case if talking to a 2014 robot? Has anyone gotten a full green with a 2014 robot?
Unread 04-08-2015, 14:27
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
You will not. The half red indicates 2014 protocol.
Edit: more properly the communication status means this: ( screen step live DS direction)
Major Status Indicators - These three indicators display major status items for the DS. The
"Communications" indicates whether the DS is currently communicating with the FRC Network
Communications Task on the roboRIO (this year it is split in half for the TCP and UDO
communication).
The 2014 protocol presumably only uses half of this hence half red / half green
