Go to Post Thanks to ... Dave, who teaches us not to worry, it’s only rocket science. - JohnBoucher [more]
  #46   Spotlight this post!
Unread 25-07-2015, 08:54
Nate Laverdure's Avatar
FRC #2363
Re: Team 254 Presents: Deadlift Technical Binder 2015
How do you compensate for the big loss of strength in the HAZs of the 6061? How do you recommend other welded-chassis teams do it? Just blow up the thicknesses and section heights? I assume you don't do any detailed FEA or any post-weld heat treatment.
  #47   Spotlight this post!
Unread 25-07-2015, 13:53
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Don't quote me on this, but I think the mechanical fasteners and gussets that help to fixture the weldments also make up for some of the strength lost to the welding process.
I haven't played with a model of a welded FRC robot in a long time, but as along as the welds aren't in a really high stress area, I can't see them failing under most FRC conditions unless the wall thickness is really thin, or you're beating the heck out of whatever it is. (See 67's 2012 bridge arm for more insight)
-Dustin Benedict
  #48   Spotlight this post!
Unread 26-07-2015, 01:27
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
Re: Team 254 Deadlift Technical Binder 2015
Originally Posted by Travis Covington View Post
We used 410 Stainless Steel to make a "disc" that pushed against a High Friction Molded Brake & Clutch Lining Sheet. It works just like a disc brake, except the forces are applied axially about the point of rotation.
As you can see, the disc spins and slides on a 3/8" hex shaft. This allowed us to install the disc brake outside of the gearbox.
I'm not entirely following why the disc rotates. Is it rotating in an attempt to grab onto a specific part of the gear? Also, is there a wall of some sort behind that it presses the gear agaibst?
Thanks for the help.
  #49   Spotlight this post!
Unread 26-07-2015, 01:39
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
The disk is hex broached, and will always rotate with the rest of the gearbox.
The piston pushes it into the brake pad, which is mounted rigidly to the rest of the robot. There's not mechanical features like a dog gear or anything -- it's just pure friction.
Here's a picture I got of it in St. Louis in the context of the gearbox, which may help some. The silvery part is the disk, the off-black part with a fiber texture is the stationary pad.
  #50   Spotlight this post!
Unread 30-07-2015, 16:11
AKA: Ahad Bawany
no team (None)
Are the splicers for your timing belts just two pieces of metal bolted together? Thanks.
  #51   Spotlight this post!
Unread 30-07-2015, 16:20
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Sort of. It has a milled belt profile to distribute the load properly. See below.
These carriage bearing blocks were quite intricate, but essentially became the entire structure of the carriage. The carriages themselves were quite weak and not very stiff. The belt and carriage blocks in the corners made the thing extremely rigid.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
  #52   Spotlight this post!
Unread 02-08-2015, 19:38
NWChen's Avatar
NWChen NWChen is offline
Alum
NWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to behold
Is there any footage/more documentation/images of Skystalker 0.2 available?
2012 - 2015 • Team 2601
  #53   Spotlight this post!
Unread 02-08-2015, 21:51
JoeyD JoeyD is offline
JoeyD is an unknown quantity at this point
How many individual structural parts are in this carriage bearing block, not including actual screws and bearings?
  #54   Spotlight this post!
Unread 02-08-2015, 23:29
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
5 (the two arms left and right, the base piece they mount to, the belt clamp backing piece, and the belt clamp itself). There are also 2 alignment pins to clock the left and right bearing arms with respect to the main body.
2001-2004: Team 100
2006-Present: Team 254
  #55   Spotlight this post!
Unread 03-08-2015, 00:20
cxcad cxcad is offline
FRC #1683 (Techno Titans)
cxcad will become famous soon enoughcxcad will become famous soon enough
Would pat fairbank release a photo album for this year's build?
  #56   Spotlight this post!
Unread 03-08-2015, 17:42
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
I didn't take many photos this year during build, sorry.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
  #57   Spotlight this post!
Unread 03-08-2015, 18:23
tickspe15's Avatar
tickspe15 tickspe15 is offline
Purdue University
AKA: Spencer Tickman
FRC #1747 (Harrison Boiler Robotics)
tickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant future
There wasn't much to take pictures of...
Team 1318: 2011-2015
Team 1747: 2015-Present
NAR (VEX U): 2015-Present
  #58   Spotlight this post!
Unread 04-08-2015, 15:59
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is offline
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
Great insight into one of the best teams in FRC (if not the best). I'd like to know a little bit more about your target build schedule if you're willing to share. How much time is spent on prototyping? Building a driveable prototype robot? This is something very few teams do, does this give great insight into how the game will play? When do you start work on the practice bot? comp bot? When do the programmers get it?
Mike Schreiber
Kettering University ('09-'13) University of Michigan ('14-'18?)
FLL ('01-'02), FRC Team 27 ('06-'09), Team 397 ('10), Team 3450/314 ('11), Team 67 ('14-'??)
  #59   Spotlight this post!
Unread 05-08-2015, 06:44
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is online now
Division by Pirates
FRC #0229 (Division by Zero)
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
If you haven't read them already I highly suggest going through 254s 2013 or 2014 Build Blogs. A bit long but very well worth it and it covers your questions.
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
