Labview Challenge 3
Labview Challenge 3
This challenge is a 4 part challenge to make a tic-tac-toe game Part 1) You will need to make a two player tic-tac-toe game. Requirements 1) Must have a two player 2) Must show if someone has won or there is a draw 3) Must show whose turn it is 4) Must be able to reset 5) Must show different marks for each player Part 2) Same as above however add in being able to play against the computer. Requirements 1) Must have a two player mode and a play vs the computer mode 2) Must show if someone has won or there is a draw 3) Must show whose turn it is 4) Must be able to reset 5) Must show different marks for each player Part 3) Tic-Tac-Toe is a game where you should never be able to win. This part is to make a computer player that you can never beat Requirements 1) Must have a two player mode and a play vs the computer mode 2) Must show if someone has won or there is a draw 3) Must show whose turn it is 4) Must be able to reset 5) Must show different marks for each player 6) Cannot beat the computer Part 4) This part is a variation of tic-tac-toe. In this version you are only allowed to have 3 marks of your kind on the board. They way this works is once you put down your 4th mark your 1st mark is removed. This continues on until someone wins. In this version try to make the computer never lose however I am not sure if that is possible so just try your best. Requirements 1) Must have a two player mode and a play vs the computer mode 2) Must show if someone has won or there is a draw 3) Must show whose turn it is 4) Must be able to reset 5) Must show different marks for each player 6) Never ending Tic-Tac-Toe version |
Re: Labview Challenge 3
Any suggestions for how to make it visual and more game-like?
My FRC experience never involved a lot of front panel programming. |
My first thought was to have a 3x3 square of buttons to select the spot you want to go, then a 3x3 text array to display the current board. With other toggle switches and displays for whos turn it is and such.
But i dont know of a way to make it where you click the game board with x's and o's |
Hope that helps. |
Here is what 2959's programmers did for this challenge:
https://www.youtube.com/watch?v=H7bqImeUZNg Well they did it this summer as part of an internship, but it was close enough to this challenge to be noteworthy. |
https://www.youtube.com/watch?v=H7bqImeUZNg Well they did it this summer as part of an internship, but it was close enough to this challenge to be kinda cool. |
#7
Finally finished! Took me about three hours in total.
I will upload it as an application for now because the code needs some more documentation. Let me know if you found a bug or if you could win in the unbeatable mode. Last edited by GuyM142 : 07-08-2015 at 13:49. |
#8
I've attached my solution, includes part 1 and 3.
I wanted to play with DVRs + recursion. My only complaint with LabVIEW in this case is you cant have a DVR of a typedef in the typedef itself. You have to cast it to a different type (Int32 in this example). For example in C you can do something like: Code:
struct Node {
int data;
Node** children;
struct Node {
int data;
void** children;
Also Bpk9p4 you picked the hardest one on my list! Last edited by wt200999 : 19-08-2015 at 10:19. |
