Go to Post It's super-ironic that a question about searching was found via searching. Whodathunk? - Brandon Martus [more]
Unread 05-08-2015, 10:18
Bpk9p4's Avatar
Bpk9p4 Bpk9p4 is online now
FRC #1756
Bpk9p4 is on a distinguished road
Labview Challenge 3
Labview Challenge 3
This challenge is a 4 part challenge to make a tic-tac-toe game
Part 1)
You will need to make a two player tic-tac-toe game.
Requirements
1) Must have a two player
2) Must show if someone has won or there is a draw
3) Must show whose turn it is
4) Must be able to reset
5) Must show different marks for each player
Part 2)
Same as above however add in being able to play against the computer.
Requirements
1) Must have a two player mode and a play vs the computer mode
Part 3)
Tic-Tac-Toe is a game where you should never be able to win. This part is to make a computer player that you can never beat
Requirements
6) Cannot beat the computer
Part 4)
This part is a variation of tic-tac-toe. In this version you are only allowed to have 3 marks of your kind on the board. They way this works is once you put down your 4th mark your 1st mark is removed. This continues on until someone wins. In this version try to make the computer never lose however I am not sure if that is possible so just try your best.
Requirements
6) Never ending Tic-Tac-Toe version
2016 Tesla Division Finalist
2016 Central Illinois Regional Finalist
2015 Newton Division Finalist
2015 Newton Quality Award
Unread 05-08-2015, 17:59
GuyM142's Avatar
GuyM142 GuyM142 is offline
AKA: Guy
FRC #3339 (BumbleBee)
GuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really nice
Re: Labview Challenge 3
Any suggestions for how to make it visual and more game-like?
My FRC experience never involved a lot of front panel programming.
2016-2017 - Programming Mentor
Curie Sub-Division Champions with 694, 379 & 1511
2015 - Team Captain & Head of Programming Crew
Carson Sub-Division Champions with 1325, 20 & 1711
First ever Israeli team on Einstein
2014 - Team Captain & Head of Programming Crew
2013 - Head of Programming Crew
2012 - Member of Programming Crew
Unread 05-08-2015, 18:36
Owen Busler's Avatar
Owen Busler Owen Busler is offline
Build Captain
FRC #0303 (Test Team)
Owen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant future
My first thought was to have a 3x3 square of buttons to select the spot you want to go, then a 3x3 text array to display the current board. With other toggle switches and displays for whos turn it is and such.
But i dont know of a way to make it where you click the game board with x's and o's
2016: Deans List Semi-Finalist/MAR Mount Olive District Engineering Inspiration Award/Buckeye Regional Second Alliance Captain/MAR Montgomery District Event Imagery Award/MAR Championship Gracious Professionalism Award
2015: MAR Mount Olive District Chairman's Award/MAR North Brunswick District Winners/MAR Championship Finalists
2014: MAR Clifton District Chairman's Award/MAR Championship Regional Chairman's Award
Unread 06-08-2015, 13:59
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
I threw together a quick starting point for the interaction with a board UI. There is no game logic behind it, just the board itself.
Hope that helps.
Unread 06-08-2015, 15:42
hardcopi hardcopi is offline
AKA: Rich Lester
FRC #2959 (The Robotarians)
hardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud of
Here is what 2959's programmers did for this challenge:
https://www.youtube.com/watch?v=H7bqImeUZNg
Well they did it this summer as part of an internship, but it was close enough to this challenge to be noteworthy.
Unread 06-08-2015, 15:44
AKA: Rich Lester
Well they did it this summer as part of an internship, but it was close enough to this challenge to be kinda cool.
Unread 07-08-2015, 07:38
GuyM142's Avatar
AKA: Guy
Finally finished! Took me about three hours in total.
I will upload it as an application for now because the code needs some more documentation.
Let me know if you found a bug or if you could win in the unbeatable mode.
File Type: rar Tic Tac Toe by Guy Morag - BumbleB #3339.rar (243.8 KB, 38 views)
Unread 19-08-2015, 00:28
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
I've attached my solution, includes part 1 and 3.
I wanted to play with DVRs + recursion. My only complaint with LabVIEW in this case is you cant have a DVR of a typedef in the typedef itself. You have to cast it to a different type (Int32 in this example).
For example in C you can do something like:
struct Node {
int data;
Node** children;
Instead you have to do something like
struct Node {
int data;
void** children;
and handle the proper typecast outside the typedef.
Also Bpk9p4 you picked the hardest one on my list!
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
