Go to Post Well, I think it's awesome and the best thing ever. But I'm biased. ;) - OldDan1168 [more]
Unread 08-06-2015, 12:21 PM
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: Custom roboRIO HAL: Where to find C library for roboRIO fpga?
You might try this tool on our website:
http://www.ni.com/download/fpga-inte...-14.0/4946/en/
However, it doesn't support fixed-point or structured registers, so it won't generate a complete API in C.
The rest of the API that uses FXP and structured registers would have to be added afterward.
As for the C++ generator that we currently use, only C++ and Java were ever supported, and Java support has been disabled ever since the WPILib HAL replaced the need for it.
I think you should either use the generator I linked above and manually add accessors for any missing-but-needed-by-you registers or you should write a C wrapper around the C++ chip object library that the HAL uses for at least the registers you care about.
