Go to Post (If Dean still says 'Nationals', how can you ridicule a rookie team for it? Come on.) - Amanda Morrison [more]
Unread 02-08-2015, 16:25
Baldstrom Baldstrom is offline
Chief Engineer
AKA: Jaden Bottemiller
FRC #4579 (RoboEagles)
Baldstrom is an unknown quantity at this point
Analysis of the drive() method
During the build season, our programming team wanted to use the drive() method with predictable results on the field. We tried adjusting parameters but never got the result we wanted, even when we dove into the source code of the RobotDrive class's drive() method we didn't, at first, understand what inputs would give us specific results. So naturally, we broke it down and analyzed it. These are our findings (attached).
Our team was using Java; we assume the method uses the same or relatively the same calculation for other programming languages.
Thanks!
Jaden Bottemiller
Unread 02-08-2015, 22:32
calcmogul's Avatar
calcmogul calcmogul is offline
WPILib Developer
AKA: Tyler Veness
FRC #3512 (Spartatroniks)
calcmogul is just really nicecalcmogul is just really nicecalcmogul is just really nicecalcmogul is just really nice
Re: Analysis of the drive() method
If you want, you could clone WPILib, commit your drive() documentation improvements, generate a patch with "git format-patch", and submit that patch in a new bug in the bug tracker. I can submit your patch for review for you.
Unread 03-08-2015, 09:07
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
Very interesting, thank you for sharing your findings! We typically directly set the motor outputs (using setLeftRightMotorOutputs()), but I once used the drive() method and also felt similarly confused by the lack of documentation. I will refer to this next time I need to use it.
www.sharkattack744.com
Unread 06-08-2015, 13:11
Xanawatt Xanawatt is offline
FRC #1024
Xanawatt is an unknown quantity at this point
This is so helpful! Might actually use this method in future years for auto purposes. It seems like it can do a lot of very complicated things!
