Go to Post This is probably one of the most important robots in FRC history and it never even was in an official event. - gyroscopeRaptor [more]
Unread 06-08-2015, 14:18
lark95's Avatar
lark95 lark95 is offline
Red Ranger
AKA: Joe L.
FRC #3418 (RoboRiot)
Team Role: Driver
lark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of light
Thoughts on driving in the previous season
So now that is has been awhile since worlds ended i was wondering what stuck out to everybody the most drivers/driving. What were some things that could be improved or some good things that worked well.
The most important thing i noticed was during the finals at Milwaukee. All three teams in our alliance did very well together. I believe that this was due to the act that before hand we all got together talked things through and had a very good plan that we stuck to. Communication between drive teams is critical.
I for one have also realized that one muffin a few slices of pizza and unlimited supplies of Mountain Dew is not a very good diet.
Unread 06-08-2015, 14:28
EDesbiens's Avatar
EDesbiens EDesbiens is offline
Passionate crackpot
AKA: Étienne Desbiens
FRC #5859 (i)
EDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of light
Re: Thoughts on driving in the previous season
I saw a lot more communication between human players and drivers this year then the two last ones... This helped a lot, in my opinion...
Lisa: Players play and managers manage.
Ralph: Do alligators alligate?
Unread 06-08-2015, 14:51
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is offline
Division by Pirates
FRC #0229 (Division by Zero)
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
Human Playing this year was much more difficult and required communication than the past two years. There wasn't much to communicate in 2013/14, but this year it made sense because of how stacking works.
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
Unread 06-08-2015, 14:55
EDesbiens's Avatar
Passionate crackpot
FRC #5859 (i)
Very true
Unread 06-08-2015, 15:59
Paperclips's Avatar
Paperclips Paperclips is offline
AKA: Audrey McMahon
FRC #0020 (The Rocketeers)
Paperclips will become famous soon enoughPaperclips will become famous soon enough
The key difference between the previous year's driving and other years of driving was primarily the style of play that was necessary. One of the most important things that Recycle Rush required was to be careful (if you didn't have something to stabilize the totes you were holding).
Our driver ended up using a control system that reflected that, one joystick for magnitude and another for direction. This ended up working well for us, overall.
Something that we originally had on the robot, but later took off was an option for field-centric driving. We ended up not using this because we discovered that it was hard to line up with the chute door using those controls.
Another thing I personally discovered was that the queuing line at Worlds is about a mile from the practice fields...
Unread 06-08-2015, 16:02
EDesbiens's Avatar
Passionate crackpot
FRC #5859 (i)
We should have used that control system... Its true that you get more precision then simple tank control...
(We got our human player run all the mile to our pit twice because one of our motor controller was dead )
Unread 06-08-2015, 19:45
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
2015 Recycle Rush, more than any other recent game, called for cool-headed drivers. Despite the name of the game, rushing was the last thing you wanted the driver to do. Yes, move quickly and surely, but never get in a rush! Most years, taking a bit of a gamble of speed over consistency might pay off in the long run; probably not in 2015.
The only time I can think that driver aggression helped us this year was in driver tryouts. We learned that yes, our stabilizer bar could be used to flip totes (actually roll them 90 degrees at a time) when used aggressively. It didn't work when done methodically. After a bit of noggin-scratching, we added some rubber tape to the bottom of the bar so we could flip totes in a more controlled fashion. We probably wouldn't have thought the problem through if we hadn't seen it work sometimes.
In 2014 Aerial Assist, communication (apart from hand signals) was only feasible with the HP behind the alliance wall, in any event. For the field-side HPs, there was only one ball to keep an eye on, so the HP could just follow the robots' (that is, the drivers') lead in most situations, and look to the drive coach for a hand signal when necessary.
In 2013 Ultimate Ascent, the HPs were behind the wall, but I imagine that loading stations and altitudes were all known before each match. The main thing that needed communication to the HPs were when to feed the colored frisbees, and when to start the HP frisbee launch. I imagine that some HPs had to guide their drivers in to the loading station, especially if their robot did not have an on board camera feeding back to the driver station.
Unread 06-08-2015, 20:39
avanboekel's Avatar
avanboekel avanboekel is offline
AKA: Adam Van Boekel
FRC #5934 (Gear it Forward, Crowbotics)
avanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant future
This is definately a result of the possibility to descore this season that was not present in the past. It was often more worth it to sit still for the last 10-15 seconds, especially when visibility was lowered because of the number of stacks. Trying to get an extra tote or 2 out at the last second wasn't worth the risk of knocking down multiple stacks.
2338 Gear It Forward | Student 2010-2013 | Mentor 2014-Present | oswegofirst.org
2013 Wisconsin Regional Winner (1732, 111, 2338)
2013 Midwest Regional Dean's List Finalist
2015 Midwest Regional Chairman's Award Winner
2015 Archimedes Subdivision Winner (1023, 2338, 3996, 1089)
2016 Midwest Regional Chairman's Award Winner
4096 CTRL-Z | Mentor 2014 | team4096.org
5934 Crowbotics | Mentor 2016-Present | crowbotics.org
Unread 07-08-2015, 08:38
lark95's Avatar
Red Ranger
AKA: Joe L.
Team Role: Driver
This was definitely rue in some of the earlier qualification matches. But in the finals i didn't see nearly so much of it.
Unread 07-08-2015, 10:28
John Retkowski's Avatar
John Retkowski John Retkowski is offline
Team 316 mentor
AKA: Wyatt. Call me Wyatt.
FRC #0316 (LuNaTeCs)
John Retkowski is a glorious beacon of lightJohn Retkowski is a glorious beacon of lightJohn Retkowski is a glorious beacon of lightJohn Retkowski is a glorious beacon of lightJohn Retkowski is a glorious beacon of light
In addition. I feel like the virtual field space this years was smaller than many recent games. Many more game pieces that were fairly large by frc standards, paired with scoring ramps and no horizontal limit restrictions for robots resulted in a field that compared to other years felt, well... cramped.
2015 MAR District Championship #1 seed Winners (w 225 & 203)
2015 Upper Darby District #2 Seed Finalist(w 272 & 5420)
2015 NE Pioneer Valley District #3 Seed Finalists (w 61 & 663)
2014 Lenape Seneca District Champions (w 3929 & 2559)
2014 Springside Chestnut Hill District Champions (w 225 & 1495)
2013 Lenape Seneca District Champions
2013 Springside Chestnut Hill Finalists
Unread 07-08-2015, 11:59
RomeroFRC5012's Avatar
RomeroFRC5012 RomeroFRC5012 is offline
Peggy Sue
AKA: Brian Romero
FRC #5012 (Gryffingear)
Team Role: Operator
RomeroFRC5012 will become famous soon enough
"I for one have also realized that one muffin a few slices of pizza and unlimited supplies of Mountain Dew is not a very good diet"
I disagree hahaha. I believe the one thing that stuck out the most was not only staying level headed but making sure the robotics truly mix together.
2013-Pre-Rookie Season
Shadowed 585/399 Quarters@ Fall Classic W/ 399 Practice Bot Apollo
2014- Rookie Year
Semifinalists@ Inland Empire, Rookie All Star, Highest Rookie Seed.. Rookie All Star@ Las Vegas, Industrial Safety Award. Imagery Award@ Galileo Division
2015- 2nd year,
Quarters@ Inland Empire.. Regional Winners@ Las Vegas (148,987, 5012)Imagery Award.. Newton Division Winners, Championship winners (118,1678,1671, 5012)
2016 Los Angeles regional winners 1197-987-5012- Creativity award winners.
-2015
-2015
-2014
Unread 10-08-2015, 00:38
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
Driving this year really worked out well for individuals able to bash their heads into a wall repeatedly, through multiple competitions, and still do the same thing over and over. It was honestly a terrible year to be on a drive team, definitely the worst out of 2012-2015. The highs of finals at events were overshadowed by the incredible tedium required to get there in 2015. The atmosphere was much more reserved ( or loud, depending on your drive coach) this year, indicative of the pressure driveteams felt to perform without mistakes each match.
(2015-?): 973
(2012-2015): 955
Unread 10-08-2015, 02:52
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
definitely the most stressful year to drive...
let's just say i won the last 2 matches in Montreal less than a second from the end buzzer
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 10-08-2015, 07:48
lark95's Avatar
Red Ranger
AKA: Joe L.
Team Role: Driver
It was certainly a much harder year to drive than last year. Last year you might get the ball 3 or 4 times and those were really the only times you could make a really bad mistake. But this year every tote had the the potential to lose you the match. It was certainly the most stressed I have ever been.
Unread 10-08-2015, 07:57
Professional Stat Padder
For the most part, I agree. But depening on your robot and team played the game in 2013/2014, human playering may have required similar amounts of communication.
2013- robots that needed precise alignment with the feeder and exclusive floor pickups that were cycling required similar communication (when 20 would cycle, we'd often pick up 1-3 stray discs off the floor, then communicate to our human player to drop 1-3 more on the floor. We didn't want to drop extra discs because opponent floor pickups could pick them up.
2014- teams with flexible strategies required really good communication with their far side human players, really smart human players, or both. (10 seconds left in the match, do I throw the ball into my team's robot or the designated finisher's robot, do I inbound the ball now when my team is being t-boned or wait until they get a better angle)
The difference, I think, is that almost every team in 2015 needed to have good drive-HP communication, while in 2013 and 2014 it was only really required for a smaller subset of teams, usually teams at higher levels of play.
As for driving between the seasons- they were very different.
2015 required extreme care. Calm, cool, and collected drivers who knew exactly what the robot was capable of were necessary.
2014 required much more aggressive drivers, depending on the robot. The drivers needed to be able to understand the robot's capability and evaluate risks when driving.
2013 depended on what robot you had, again. Most drivers just needed to be agile enough to juke defenders out, then careful lining up their shots. Full court shooters generally needed to be careful and get into position, because they were often top-heavy and only needed to get there once, while floor collectors needed to move a bit slower and more carefully to carefully grab the floor discs.
I think the takeaway is that drivers need to be practiced and really know their robot inside and out regardless of year, but many requirements for drivers otherwise change year-on-year.
(2015-Present)
