Go to Post I would not want the task of devising a system that 50,000 very smart people try to outwit. - texarkana [more]
Unread 06-08-2015, 19:28
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #1072 (MVRT)
RS-395 safe loading
I'm trying to figure out more ways to cut weight in my swerve drive, and am considering using an RS-390 or RS-395 for the module turning motor in place of the usual RS-550 (1/4lb savings).
According to JVN calc, I'm gearing it down 74:1 and that results in a 210RPM free speed. It draws 4.1A under typical load, that is, all 4 wheels on the ground on a 150lb robot. When sitting on two wheels it's loaded at 7.6A.
Is this a safe current to run through an RS-395 through a match for a swerve drive, or should I stick with a 500-series motor?
Unread 06-08-2015, 19:47
AdamHeard's Avatar
Lead Mentor
Re: RS-395 safe loading
Not worth it, stick with the heavier motor.
Unread 06-08-2015, 20:02
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
I haven't used the RS-395, so I'm not familiar with its durability, but applying a bit of common sense:
Under typical steering, you're drawing about 1.5x the current that the motor draws at maximum efficiency. That should be golden, especially for match durations. If almost all of your drive time is in a straight line or gentle curve, probably all day without a break.
Under "peak" conditions you're essentially running the motor at its maximum power point. Unless you're planning to recreate Tumbleweed for a near-circular race game*, you should be good. If regular peak conditions are anticipated, you're on the bubble of common sense and will need some definite experience or testing to determine if the motor can run at this current for a full match.
Unread 06-08-2015, 20:07
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
So your savings overall would be 1lb?
It really doesn't sound like it would be worth it.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 06-08-2015, 20:54
Scott Kozutsky's Avatar
Scott Kozutsky Scott Kozutsky is offline
FRC #0865
Scott Kozutsky will become famous soon enough
1717 used 395s (I think, could be 390s) with undeniable success. I don't know about the gearing or issues they had with them but they definitely work.
http://wiki.team1640.com/index.php?t...awesome_pivots
1640 used a 395 in 2012 and upgraded to a 540 in 2013 (both using a Banebots 133:1 planetary) according to their BOM. I don't know the reason for the change.
I wouldn't bother.
edit: 550s were used instead on 1717 swerve.
2010-2012 FRC 865 Warp7 Student, Mechanical
2013 FRC 1310 RUNNYMEDE ROBOTICS Student, Mechanical, Design
2014 FRC 865 Warp7 Student, Mechanical, Design
2015 FRC 865 Warp7 Alumni, Mechanical Mentor
Unread 06-08-2015, 21:04
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
I wouldn't bother.
Which year did 1717 use 395s?
R.C.
MadTown Robotics Team 1323
Unread 06-08-2015, 21:19
FRC #0865
2012 at least. The linked pic library shows what I think is a 395 (maybe the 390- I can't distinguish them visually). I vaguely remember them saying it was a 395 on their 2013 and 2014 bots but I honestly can't remember.
edit: am mistaken-550s were used instead.
Unread 06-08-2015, 21:43
asid61's Avatar
AKA: Anand Rajamani
FRC #1072 (MVRT)
Well it's basically a free pound, so why not?
I think I'll design for both for now, and try them out as needed.
Unread 06-08-2015, 22:29
Jared Russell's Avatar
Taking a year (mostly) off
Steering motors can be loaded in lots of unexpected ways. Trying to turn when your wheel is up against an obstacle or imperfection in the floor...when dynamics shift most of your normal force onto one or two wheels...on slopes...during intermittent bouncing contact with the floor...
Also, the 300-series motors have not been used nearly as often in FRC as the 500- and 700- series motors. There is less (not none, but less) collective community experience in knowing their limits and endurance under FRC loads. Spec sheets seldom tell the whole story (especially when you are talking about a fairly generic trade sized motor from China).
Given the severity of losing a steering motor, my personal inclination would be to accept the 1 lb penalty and look for opportunities to save weight elsewhere.
EDIT: Also, out of curiosity, what method did you use to calculate the load on each motor in a steering application?
Unread 06-08-2015, 22:35
Gdeaver Gdeaver is offline
FRC #1640
Yes, 1640 used RS395 motors 1 year. Decision was based on motor availability. The 395's performed OK that year but we did burn up a few. That summer active cooling for them was explored. Heat was a problem. Since then RS540's have been used with great success. We also added a quick change feature to the Banesbot trans and motor mount. the motor, pinion and base plate can be removed and replaced without total transmission removal. 2014 was the most abusive year for our swerve. The 540's held up but were routinely hot after matches. The 300's would not have worked in that game. Do not under estimate the amount of power needed for future games. RS540's are probably the minimum. 2015 put absolutely no stress on our swerves. 300 would have worked.
Unread 06-08-2015, 22:56
asid61's Avatar
AKA: Anand Rajamani
FRC #1072 (MVRT)
I used the JVN calc "rotary mechanism" tab. To calculate load I used
wheel width * 1/4 bot weight * CoF. In my case that was 0.75*37.5*1.3, or about 36lbs. Then I added a ~1.5x factor of safety and decided on 50lbs as a good estimate for loading.
Based on what I'm seeing here I guess I'll just suck it up and use a 500. Kind of unfortunate, but I'll take what I can get.
EDIT: Whoops, that calculation is wrong. The load on the wheel is equal to 150lbs/4 wheels * 1.3 CoF, or 48lbs. The lever arm is 1/2 the wheel width, or 3/8".
Unread 06-08-2015, 23:13
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
We ran our swerve steering on 550s through 49:1 Versaplanetaries and then to an 84:24 reduction for a total reduction of 171.5:1 and they got REALLY burning hot. It was kind of surprising and somewhat concerning. It may be due in part to inefficiencies in the Versaplanetaries. I think the frequent direction reversals and PID position holding are also a contributing factor.
Unread 06-08-2015, 23:34
FRC #1836 (MilkenKnights)
1/4 bot weight per wheel is a best case scenario. Expect to routinely get pushed onto one or two wheels during pushing matches and having more weight on certain wheels when accelerating. 1/2 or 3/4 * bot weight seems like a far safer number.
Drivetrain is a terrible place to try to skimp out on. I want my drive to be as reliable as possible. I'd be especially concerned with the intensity of pushing matches and the small breaks between matches during eliminations, where reliability is the aspect that differentiates between teams the most.
In my mind, reliability trumps weight in this situation given that 540s are already pushing limits because they aren't very well suited to the needs of your steering motor.
Unread 06-08-2015, 23:41
R.C.'s Avatar
Scott I think your off here. 1717 has for sure used 550s over the the past few years. For 2012 in that wiki it says as well:
2012 - Unicorn Drive, CIM+Custom Shifters & 550s
In 2012, our drivetrain consisted of four independent wheel modules. Each wheel module’s drive was powered by one CIM motor with a two-speed custom gearbox. Our wheel modules' turning was powered by a single Banebot RS-550 with a custom transmission. All of our gears were made from aluminum and they were cut in house.
R.C.
Unread 06-08-2015, 23:56
FRC #0865
whoops, I feel like an idiot. previous posts edited.
