Go to Post FRC is a big tent. There's room for everybody. - Ether [more]
Go Back   Chief Delphi > Technical > CAD
Unread 05-08-2015, 21:04
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Designing A Light Robot
I was wondering what tips and tricks your team uses to design a robot that is light and effective? What lightening patterns does your team use? Where do you use 1/8in wall vs 1/16in wall? ect.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 05-08-2015, 22:04
FRC #1836 (MilkenKnights)
Re: Designing A Light Robot
Building a light robot is all about materials and geometry.
We use 2" x 1" x 1/16" wall 6061 aluminum tube everywhere, except for the drive side rails. The tube is plenty strong for FRC purposes. The only issue we have ever had with 1/16" wall tube is crushing the tube by over tightening screws. Using 7075 aluminum instead of steel and #10 screws instead of 1/4-20 helps a lot too.
As far as geometry goes, try to triangulate and use flanges to build rigid but light structures. We also try to use as little lightening as possible, preferring to use thinner materials instead.
Unread 06-08-2015, 00:07
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
FRC #0314
RonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond repute
Minimize your bolt use and get some aluminum rivets. You would be surprised how much lighter your robot gets if you go through and design the entire bot first with material applied correctly. When you just pick up parts and start building you don't have a grasp for real weight until you pull out the scale and realize your 20 pounds over.
-Ronnie
"Do not argue with an idiot. He will drag you down to his level and beat you with experience"
Unread 06-08-2015, 02:01
Munchskull's Avatar
Team Role: CAD
My team already uses aluminum rivets. How much differences does using 10-32 bolts make?
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 06-08-2015, 10:17
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Mostly, we stopped using 80-20, started using KISS. It's better to never build a 10 pound tertiary manipulator than to shave 10 pounds off your drive chassis or primary manipulator in the last few days before bagging.
As others have said, use materials (especially fasteners and adapters) with good strength-to-weight ratios.
Also, use parts that actually fit together with at most a single adapter. For a prototype, you can bolt two hubs together for a shaft adapter. On the real robot, use the right shaft from the start or spend the money for a COTS shaft coupler.
Develop a weight budget and weigh sub-assemblies regularly (every build session). Learn to recognize that you're going to be overweight early enough in the process to take corrective measures (parts replacement, redesign or reallocation) that preserve functionality.
Unread 06-08-2015, 22:13
Rivets (especially aluminum rivets) will be far lighter than bolts. 10-32s are about 30%-40% lighter than 1/4-20 bolts, which can probably save a couple pounds depending on how many bolts you use.
Unread 07-08-2015, 00:19
Munchskull's Avatar
Team Role: CAD
Also my team often uses 1/8" sheet metal for structural attachment, is that overkill?
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 07-08-2015, 00:38
For gussets, probably. We usually do 1/16" unlightened gussets or 1/8" lightened gussets. Honestly though there isn't a lot of weight to be saved there.
Unread 07-08-2015, 00:58
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We usually let the chassis be heavy, so we are forced to make the rest of the robot light. And we like using a variety of materials. Thin aluminum tube, polycarbonate sheet, thin aluminum gussets, thin plywood, etc. If you do it right, you can have some weight budget left over, and maybe put a couple wood 2x4s in the bottom of the robot, to impress the judges.
Unread 07-08-2015, 16:16
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Since strength wasn't all that important this season, we used 1/16" tubing everywhere. Wherever we could, we used rivets, and wherever we couldn't use rivets, we used aluminum bolts. (except on the collector... learned that lesson the hard way) Aluminum bolts are way lighter, although they aren't nearly as strong.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 08-08-2015, 20:39
Munchskull's Avatar
Team Role: CAD
Where do you purchase aluminum bolts?
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 08-08-2015, 21:19
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
http://www.mcmaster.com/#aluminum-cap-screws/=yevh92
Unread 09-08-2015, 07:34
IKE's Avatar
IKE IKE is online now
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Minimizing thickness is my preferred method.
In a 2 foot long piece of 1x1 box, how many lightening holes does it take for 1/8 to match 1/16 with no holes...
Unread 09-08-2015, 17:30
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
You don't want to use aluminum bolts in 99.9% of FRC applications...and anywhere you might, you'd be better off using nylon bolts (screwing electronics down is the one area that comes to mind).
Aluminum bolts are going to shear very easily, as well as potentially gall, since most threaded mating parts in FRC are aluminum also.
2001-2004: Team 100
2006-Present: Team 254
Unread 10-08-2015, 09:03
evanperryg's Avatar
AKA: Evan Grove
This is an important thing to consider. We made the fatal decision of using aluminum bolts to attach our collectors at Wisonsin, and got knocked out in quarters after one of them sheared.However, we did use them in other areas on the robot where they weren't taking so much stress, and never had an issue with them.
2013
2015
