Go to Post Inspiration and recognition does not equal "advanced shop class". What's better for your team is not better for all teams. Remember that. - DonRotolo [more]
Unread 08-08-2015, 21:41
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: ThunderHex inspired question
If you're already thinking of turning a hex shaft down to fit into a round bearing, I'd recommend using a small enough bearing that you get 100% contact. The sheet metal on bearings is mostly meant to hold the bearing together when it is between assemblies, not to distribute the forces tangentially.
A less desirable alternative would be to add a spacer with a hex bore and an outer diameter that fits into a larger bearing. This would also need to be held in place with a shaft collar or similar.
