Go to Post The teams that know how to build good robots are the same teams that know how to build good teams, and they engage the students every step of the way. - Chris is me [more]
Unread 08-08-2015, 23:51
mlantry mlantry is offline
I'm back
AKA: Matthew Lantry
mlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud of
3d printed wheel
To put a little perspective into the choices made for this project some back story is needed. With the team I work with it is difficult to order parts quickly (can take 2 weeks for an order to be submitted to the company we wish to order from) as well as has to be an approved vendor (no McMaster Carr ). Thanks to this thread ( http://www.chiefdelphi.com/forums/sh...hlight=Banebot ) it gave me an idea to create and try a 3d printed wheel for use in different mechanisms but then a new issue arised what could be used for tread? So me and my friend scoured our local home depot looking for a good tread material and came up with using rubber tie down strap which had a surprising amount of grip and through our testing seemed to wear pretty well. The wheel it self held up very well and is alot stronger than I was expecting. The changes (we already knew we needed to do these things) it needs to be done only with a key or a hex shaft because a set screw method was not very effective. Also we would want to increase the number of shells for the print. Also it is to wide for the tread.
Matthew Lantry
Team 4475 2014-present
-College Mentor 2014-????
Team 1676- 2011-2014
-Mechanical 2011-2014, Subteam leader 2013-2014
-Robot Operator 2014
George G. White FLL mentor 2011-2014
“Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute.”
Unread 09-08-2015, 00:38
nate12345678's Avatar
nate12345678 nate12345678 is offline
Programming Lead and Scouting Lead
AKA: Nate Post
FRC #2338 (Gear It Forward)
nate12345678 will become famous soon enough
Re: 3d printed wheel
Clever idea! Maybe try a concave torus for the next model, that way the support does not protrude out at all.
edit: Saw Brian's post, I didn't even look at it initially. (He's my mentor)
Unread 09-08-2015, 05:47
DaveL DaveL is offline
FRC #2976
DaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the rough
Hi Matthew:
It might be interesting to test the performance of sideways and diagonal cuts in the tread, to see how that affects your traction and wear.
Dave
Unread 09-08-2015, 18:26
I'm back
AKA: Matthew Lantry
Originally Posted by DaveL View Post
Hi Matthew:
Dave
Definitely considering it I know some teams have do similar things to colsons with great results
Matthew Lantry
