Go to Post *puts on flame suit and goes to hide in the corner* :D - Wayne Doenges [more]
Unread 04-08-2015, 09:47
wgardner's Avatar
wgardner wgardner is offline
wgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to behold
Re: [FTC]: Drive Platform- Design Exercise
Great! I look forward to seeing pix of the final result, and learning how much torque it can withstand.
Cheers.
CHEER4FTC website and facebook online FTC resources.
Providing support for FTC Teams in the Charlottesville, VA area and beyond.
Unread 04-08-2015, 18:30
DavisDad's Avatar
DavisDad DavisDad is offline
MechE
AKA: Craig Rochester
FTC #8470 (Team Technado)
DavisDad will become famous soon enoughDavisDad will become famous soon enough
OnShape has just published a curriculum package: LINK
  1. Onshape offers a completely free version of its software with all the same functionality as the professional version – and it’s engineered to be easy to set up and get started.
  2. Immediate Access: You and your students can go here and set up your free account in less than two minutes!
  3. Curriculum Guidance: Onshape is creating curriculum for teachers to use in their classrooms. A free Instructor Kit is available now. The kit contains videos, exercises, and quizzes – including an instructional video teaching you how to use the kit – and covers everything that first-time users need to know to learn CAD.
Unread 04-08-2015, 19:06
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Originally Posted by wgardner View Post
FYI, if you're considering this CAD model for use on a real robot, you might want to read some of the reviews on the Dremel angle drive complaining of lack of durability. It's probably made for high speed but not necessarily high torque. It would be a shame to buy 4 of them at $20 each, build a robot based on them, and then find that they break the first time your robot runs into a wall or another robot, stalling your motor.
Even if you solve the durability problem, the roller-on-roller transfer of energy from one axle to the other is not likely to transfer much torque (though it would be good for high-speed, low torque applications, like attaching to a dremel). With that device in your drivetrain on the wheel side of the gearbox, I doubt you would be able to get anywhere near stalling the motor; I'd be more worried about not getting enough traction to get the robot rolling at all. I don't know the contact force or coefficient of friction, so I can't even give a rough numerical estimate of the torque, but it's something else you should check before including it in your design.
Unread 04-08-2015, 21:50
DavisDad's Avatar
MechE
Originally Posted by GeeTwo View Post
...the roller-on-roller transfer of energy from one axle to the other is not likely to transfer much torque...
The gearbox has straight bevel gears; my model's simplified representation doesn't show the the teeth.
Unread 05-08-2015, 03:17
mhaeberli mhaeberli is offline
FRC #3045
mhaeberli is on a distinguished road
Nice work!
On a very distantly related note, are there any suggestions anywhere as to how to set up an Android Virtual Device Emulator to closely track the ZTE Speed? Obviously, one wouldn't be able to do more than test out stuff not directly related to motor control, etc, except maybe with some input and output test files...
Thanks,
Martin
(one of the mentors for FTC #7593 TigerBots).
Unread 05-08-2015, 06:37
DavisDad's Avatar
MechE
Hi Martin,
Have you seen the threads at the FTC forum. There's a lot of activity there. Here's an example:
Thread: End to end response times
Unread 05-08-2015, 11:37
FRC #3045
Thanks!
Unread 05-08-2015, 19:49
DavisDad's Avatar
MechE
Here's a photo and CAD of angle gear. The square shaft is pretty light, but the design is cool as square drive shaft is routed through the hollow shaft and press fitted at the gear end. There's a lot of flex which make alignment with motor easy. I'll test for ability to handle about 1500 in-oz.
Unread 06-08-2015, 07:48
DavisDad's Avatar
MechE
Looked at stress in square shaft. Assumed round shaft 2.5mm diam and 500 in-oz (3.53 Nm) and plugged into this on-line calculator: TORSION OF SOLID AND HOLLOW SHAFTS
It returns 160 kPSI (1100 MPa). That about 5x the the stress to break a steel rod. It's not looking good for the square shaft. Now I need to look at the gears; they probably aren't designed for the torque either...
Last edited by DavisDad : 06-08-2015 at 15:06. Reason: fixed 500 in-lb --> 500 in-oz
Unread 06-08-2015, 08:26
wgardner's Avatar
If the dremel drive doesn't work out, you could probably make your own version using the bevel gears at ServoCity and some Actobotics parts, like what is shown at the bottom of this link. So far, we're quite happy with the 1/4" axles of the Actobotics set: they're much stronger than the Tetrix axles and the bearings for the Actobotics axles seem much nicer than the bronze bushings used in the Tetrix set.
Unread 07-08-2015, 18:10
DavisDad's Avatar
MechE
Thanks for the link, and the price is right. The same steel gears from mfgr are about $25 ea.
Unread 08-08-2015, 22:54
DavisDad's Avatar
MechE
I tested the angle drive for torque strength. I jigged it up and applied force with a torque wrench set at 20, 25 & 30 in-lb (480 in-oz). At 30 in-lb, the shaft started "unraveling", twisted and broke. It's a bundle of wires formed into a square shaft.
I'll drill out the wire shaft and make a coupling to press fit into the 4mm ID/6mm OD bearing shaft.
Unread 11-08-2015, 09:12
wgardner's Avatar
Originally Posted by DavisDad View Post
I've been spending some time working with OnShape.
I'm looking for CAD models of the Modern Robotics components and your nice picture is all that I can find so far.
Did you make that model yourself or get it from somewhere? Are there models for the other components? If you made them yourself, would you be willing to export them and share them?
Thanks!
Unread 11-08-2015, 09:58
DavisDad's Avatar
MechE
I've modeled the new motor, servo and main power modules. They are "public" at OnShape. I can export to most file types; what do you prefer?
Unread 11-08-2015, 10:09
wgardner's Avatar
Great! I'll just find them myself on OnShape! Thanks!
