| Thread Tools |
Rating:
Display Modes |
#16
Re: FRC Blog - Behind the Scenes at IRI
It would be nice for FIRST to be early adopters of 802.11AD since it utilized a 60GHz frequency. Less interruptions and interference, huge bandwidth (why it's called WiGig) and due to the nature of 60GHz antenna modules vs 2.4GHz antenna modules, the same size package can have far more antennas per module on the order of 32 vs 1. Additionally, there are benefits with efficiency and power consumption. Unfortunately 60GHz reflects rather than penetrates most surfaces so this does affect connection, but from previous network setups at competition, I doubt that would be a huge issue.
Source http://www.networkworld.com/article/...i-picture.html |
#17
Here's a little something to get you started. |
#18
Pretty sure this radio is a hair smaller though, FWIW.
#19
I don't know why but it just occurred to me that these new APs have a lesser number of ethernet ports on them. Not necessarily a problem but could facilitate adding a switch for some teams. Just a thought.
#20
The radio shown is very small, about 1/4 the footprint of the current radio. It is available with or without the dual band capability. Currently FRC is using the 5 GHz band for competition. The radios tested at IRI did have a POE marking on the jack although I would expect that feature would not be used if this radio will be used. In watching mounting the radio on the various robots, the current general rules for radio mounting still applies. That is high on the robot, away from surrounding metal objects and local interference devices like open frame motors. It does have a 12 volt input. The antennas are mounted on the sides of the radio so conventional wisdom would be to mount horizontally to maximize coverage and to keep objects away from the sides. Robot rules about keeping the LEDs visible should still apply. |
#21
I would think we'll still be using a barrel jack. There would be minimal benefit to using PoE in FRC, especially considering there's only one or two ethernet cables in the entire robot.
#22
I didn't realize how small this was when I first saw the picture with the goat. I am pleased.
#23
Could we re-schedule IRI for June 20th? |
#24
Replace software development with ritual chanting. Replace auton with waiting for sunrise. |
#25
I think I'm more excited to see stonehenge than I am to watch another round of recycle rush though...
#26
We are in a revolution of automation and mechatronics. Learn it , embrace it. It is your future.
#27
Introducing the 2016 FRC game, stonehenge strike!
#28
You have 100ms to knock down as many stones as possible and then thousands of years to wait for the score.
![]() What was this thread about? Ohh yeah, IRI and the new wireless widgets. Anyone have experience with putting an ethernet switch on the robot. Is it legal? I recognize that we use more ethernet ports than the average team but just curious. |
#29
Per the current rules, the roboRIO must be directly connected to the radio, but I can't find anything that disallows a switch on the robot for other devices. With the VRM, its definitely much easier to get power to a switch then the old control system.
#30
