Go to Post I just... I can't even comprehend it. Like, my brain is soup. Commas are everywhere. Sentences. Shrinking. zzzzzzzzzzzz... - PayneTrain [more]
Unread 26-07-2015, 18:34
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
Re: FRC Blog - Behind the Scenes at IRI
It would be nice for FIRST to be early adopters of 802.11AD since it utilized a 60GHz frequency. Less interruptions and interference, huge bandwidth (why it's called WiGig) and due to the nature of 60GHz antenna modules vs 2.4GHz antenna modules, the same size package can have far more antennas per module on the order of 32 vs 1. Additionally, there are benefits with efficiency and power consumption. Unfortunately 60GHz reflects rather than penetrates most surfaces so this does affect connection, but from previous network setups at competition, I doubt that would be a huge issue.
Source http://www.networkworld.com/article/...i-picture.html
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 26-07-2015, 20:13
E Dawg E Dawg is offline
... is not done with FRC yet.
AKA: Ethan
FRC #0159 (Alpine Robotics)
E Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud of
My ideal is a pure mechanical robot, zero volume and weight allocated for electronics and wires.
https://www.youtube.com/watch?v=s1i-dnAH9Y4
Here's a little something to get you started.
Unread 26-07-2015, 21:45
PayneTrain's Avatar
PayneTrain PayneTrain is offline
no
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
Originally Posted by Nemo View Post
One of these years, the radio will get smaller, right? I know practically nothing about wireless technology, but one of the things I do know is that you can fit it into a phone or a VexNet key.
Pretty sure this radio is a hair smaller though, FWIW.
Unread 09-08-2015, 21:55
marshall's Avatar
marshall marshall is online now
FRC #0900 (The Zebracorns)
I don't know why but it just occurred to me that these new APs have a lesser number of ethernet ports on them. Not necessarily a problem but could facilitate adding a switch for some teams. Just a thought.
Unread 10-08-2015, 07:48
This includes plastics too...
The radio shown is very small, about 1/4 the footprint of the current radio. It is available with or without the dual band capability. Currently FRC is using the 5 GHz band for competition. The radios tested at IRI did have a POE marking on the jack although I would expect that feature would not be used if this radio will be used. In watching mounting the radio on the various robots, the current general rules for radio mounting still applies. That is high on the robot, away from surrounding metal objects and local interference devices like open frame motors. It does have a 12 volt input. The antennas are mounted on the sides of the radio so conventional wisdom would be to mount horizontally to maximize coverage and to keep objects away from the sides. Robot rules about keeping the LEDs visible should still apply.
Unread 10-08-2015, 09:13
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Originally Posted by PayneTrain View Post
I've heard it's the same barrel jack we already use, but it takes 12V.
Also a PSA: just because they have shown us what the radio is, don't go out and buy it expecting it to be official, then complain if FIRST takes a different direction.
I would think we'll still be using a barrel jack. There would be minimal benefit to using PoE in FRC, especially considering there's only one or two ethernet cables in the entire robot.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 10-08-2015, 20:20
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
I didn't realize how small this was when I first saw the picture with the goat. I am pleased.
Unread 10-08-2015, 21:10
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
That would be ideal for next season's game: http://tinyurl.com/frc2016
Could we re-schedule IRI for June 20th?
no stranger to the working end of a pencil
Unread 11-08-2015, 05:56
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Take FRC back to the Stone Age? Pity teams who have to queue up and place robots like this on the field. Pity volunteers if these are the field elements.
Replace software development with ritual chanting. Replace auton with waiting for sunrise.
Richard Wallace
since 2003
Unread 11-08-2015, 07:56
marshall's Avatar
I think I'm more excited to see stonehenge than I am to watch another round of recycle rush though...
Unread 11-08-2015, 08:04
Gdeaver Gdeaver is offline
FRC #1640
We are in a revolution of automation and mechatronics. Learn it , embrace it. It is your future.
Unread 11-08-2015, 10:10
evanperryg's Avatar
AKA: Evan Grove
Introducing the 2016 FRC game, stonehenge strike!
2013
2015
Unread 11-08-2015, 10:21
marshall's Avatar
You have 100ms to knock down as many stones as possible and then thousands of years to wait for the score.
What was this thread about? Ohh yeah, IRI and the new wireless widgets.
Anyone have experience with putting an ethernet switch on the robot. Is it legal? I recognize that we use more ethernet ports than the average team but just curious.
Unread 11-08-2015, 11:16
Per the current rules, the roboRIO must be directly connected to the radio, but I can't find anything that disallows a switch on the robot for other devices. With the VRM, its definitely much easier to get power to a switch then the old control system.
Unread 11-08-2015, 11:27
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
In the 2015 rules, this would be covered by R48:
Ethernet-connected COTS devices or CUSTOM CIRCUITS may connect to any remaining Ethernet port on the DAP-1522 Wireless Bridge but must not transmit or receive UDP packets using ports 1100-1200 with the exception of ports 1130 and 1140.
Note that R47 specifies that the roboRIO be connected directly to the bridge (or through an Ethernet pigtail), and that all applicable power rules be followed (R32 comes to mind)- if it's a powered switch you would probably want to supply it with regulated voltage, and odds are it would want 5V.
2016: Lake Superior WFFA
