Go to Post FIRST has set me on a completely different path in life. And I'm all the better for it. - Vincent Chan [more]
  #31   Spotlight this post!
Unread 12-08-2015, 20:42
DonRotolo's Avatar
Back to humble
FRC #0832
Re: pic: Cheesecake, anyone?
Originally Posted by efoote868 View Post
Details.
Compare and contrast. The crust has a crumbly, pitted texture..
Darn that is a really good rendering of a cheesecake.
In all seriousness, there is no technical issue preventing you from printing a cheesecake, or a pizza for that matter - but you'd still need to bake the pizza.
McD's uses high-speed large-capacity printers, but they've found real wheat buns are more cost-effective.
As for the filament cartridges, Cheddar isn't the right material for this kind of cake.
What's scary about this thread is that it can turn into a real, serious discussion at any moment. And there are people here with the chops to actually do it. I mean, they already print chocolate and cupcake icing...
  #32   Spotlight this post!
Unread 12-08-2015, 20:57
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Well 3D printers can be enclosed.
Easy Bake ovens are enclosed.
I did once suggest using an incandescent light bulb as a 3D printer enclosure heater.
Turn up the wattage - or better yet - use an infrared lamp and lower it to the pizza to produce localized heating (runs to the pizza patent office).
  #33   Spotlight this post!
Unread 12-08-2015, 22:26
hectorcastillo's Avatar
hectorcastillo hectorcastillo is offline
Former Driver and Captain for 3481
FRC #0125 (NUTRONs)
hectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to all
We're coming for you, Papa John's!
365 Decontaminators (FLL) 2011 - 2012
6221 Panther Bots Alpha (FTC) 2012 - 2016
3481 Bronc Botz (FRC) 2012 - Present
125 NUTRONs (FRC) 2017 - Present
  #34   Spotlight this post!
Unread 13-08-2015, 10:35
Darkseer54's Avatar
Darkseer54 Darkseer54 is offline
Former Controls Captain and Driver
AKA: Zach Kaplan
FRC #1086 (Blue Cheese)
Darkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of light
What would be better though, this method or finding a way to heat the bed to a high enough temperature to cook the pizza? I have no experience cooking pizzas so I don't know how they are generally cooked, but wouldn't heating the bed make it so that it wouldn't have to be enclosed? Also I have no idea if a 3d printer's bed can get to a high enough temperature to cook a pizza.
2014: IRI on a losing record.
  #35   Spotlight this post!
Unread 13-08-2015, 13:14
tr6scott's Avatar
tr6scott tr6scott is online now
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Originally Posted by hectorcastillo View Post
The slice is 1.42in tall, has a 2.35in radius, and a 50 degree angle.
Who designs a slice of cheesecake to be 7.2 pieces per whole? No one will settle for the 0.2 piece. That's just crazy talk.
Iter-ate... one more time.
The sooner we get behind schedule, the more time we have to catch up.
  #36   Spotlight this post!
Unread 13-08-2015, 14:13
techhelpbb's Avatar
Heated beds from printed circuit boards might survive this. It would probably take several heater cartridges to get the heating even. Then again there is good old nichrome or Inconel wire.
  #37   Spotlight this post!
Unread 13-08-2015, 17:56
FRC #0125 (NUTRONs)
Uhhh... the cake is cone-shaped and there are 350 degrees around the center. I cut it into seven pieces because 7 is a nice number... also America.
  #38   Spotlight this post!
Unread 13-08-2015, 20:04
DonRotolo's Avatar
Back to humble
FRC #0832
You need to get out more. Or at least observe more closely. Surely there is a non-chain type Pizzeria near you? Go visit and ask questions (as if you were in the pits at a regional...) Living in northern NJ would help (pizza capitol of the world, arguably).
Pizza ovens are generally at 450 to 500 degrees. They universally have stone 'floors' to maintain the temperature evenly and avoid the cooling effect of an uncooked pizza. So yes, one CAN make a bed that will cook a pizza, but you really want to print it first, then cook it.
  #39   Spotlight this post!
Unread 15-08-2015, 00:05
Henrique Schmit's Avatar
Henrique Schmit Henrique Schmit is offline
FRC #1156 (Under Control)
Team Role: CAD
Henrique Schmit is an unknown quantity at this point
ABS printers alraedy have heated beds, so you could base your bed on something like that, they go up to ~110ºC
Sadly, no. We couldn't get anyone to agree to this. Our current plan is to print it using an industrial triple injection 3D printer, but instead of feeding it ABS filament, we're going to use cheesecake, whipped cream, and whatever the crust is made of. As you can see, we have left plenty of room in the design for expansion... (i.e. cherries)
Has anyone figured out how to print the irregularities in the cake to make it more accurate and useful? Maybe adding bubbles inside the filament would create a pattern like that
Ready for the water games
http://i.imgur.com/QQXtifE.jpg
  #40   Spotlight this post!
Unread 15-08-2015, 01:00
Chief Hedgehog's Avatar
Chief Hedgehog Chief Hedgehog is online now
FRC #4607 (C.I.S.)
Chief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond repute
Ummm... Are we talking per capita? Because here in Becker, MN we have 4 different joints in a town of 4500; or one pizzeria per 1125 residents. And if you include the local bars and c-store, it jumps to 7; or one per 643 residents. Only one is a national chain. We love Pizza and robots here in Becker!
"An error does not become a mistake until you refuse to correct it" ~JFK
  #41   Spotlight this post!
Unread 15-08-2015, 14:07
DonRotolo's Avatar
Back to humble
FRC #0832
My focus was on quality and variety, not per capita.
  #42   Spotlight this post!
Unread 15-08-2015, 16:13
Electronica1's Avatar
Electronica1 Electronica1 is online now
Former Design and CAD Captain 1086
AKA: Alexander Kaplan
FRC #0401 (Copperhead Robotics)
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
Maybe this style of printer would work for pizza/cheesecake. But, would this be considered a pizza printer?
  #43   Spotlight this post!
Unread 15-08-2015, 17:28
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Yes, yes. An automated pizza baker would definitely have to have separate construction and baking chambers; unless you print the bubbles in, the crust has to have time to rise at a lower temperature, and go quickly to a much higher one. (I suppose you could move the pre-heated stone to the pizza, but that sounds even more problematic.) I also seriously doubt that current 3-D technology can passably reproduce a hand-tossed and pressed crust, or even a machine-kneaded and rolled one.
  #44   Spotlight this post!
Unread 23-08-2015, 20:38
Darkseer54's Avatar
AKA: Zach Kaplan
It seems that we have been beaten to the punch on pizza 3D printers.
https://www.youtube.com/watch?v=MGxr3boyIus
Now the real question is if it can add pineapple and ham.
