Re: High Torque Gearboxes
If you're talking within the realm of COTS FRC, something has to give here.
With single CIM, the GEM500 from Andymark is reasonable. If you provide another reduction after it, the plastic 3 stage gearbox from Vex would work too. Even if you paid to get some plates cut to build another stage it wouldn't be very expensive. COTS gearing from other industries is unlikely to accept dual motor input, so that will rule out a good deal (you'll also find that gearing for pretty much any other industry will be more expensive). Quote:
EDIT: Worth pointing out that 2 CIMs at 70:1 is enough torque under stall to break many things that sometimes are assumed to be bulletproof in FRC. You'll want to verify the material for the output shaft can handle the torque (along with whatever the output gearing is) and/or limit the systems ability to maintain full stull at full voltage. Last edited by AdamHeard : 13-08-2015 at 17:51. |
VexPro advertises the use of two 10:1 reduction stages to achieve the 100:1 reduction. Are the gearboxes actually useable at this reduction? What are some experiences with them breaking?
Good luck, it's a fun competition (I was with the Iowa State team 2012 and 2013) -Aren Last edited by Aren_Hill : 13-08-2015 at 18:28. |
Your robot was incredible that year. |
SDSM&T, 2012, for me. Try 775-18s for a direct drive via BaneBots gearboxes, maybe--that's what we used that year, 4 of 'em. Just make sure your circuit protection--and speed controllers--can handle the current. I don't think we ever blew a fuse (yep, we used inline fuses) but we also had speed controllers that would shut off under high-current conditions (say, about 3-10 seconds into a run) and not reboot. So we got some without that safety and... well... It worked until we dug ourselves into a small hole and got stuck on our last run. We could smell the smoke when we opened the case.
Also, can anybody speak to how well the Gem500 (and mounting bracket) can handle side loads to the output shaft (30-50lbs)? |
#7
Also, with 4 stages, it is possible to corkscrew the output shaft so run your calculations carefully before running it on a robot. |
#8
Just the speed controllers--the 775s worked like a charm if the controllers weren't taking a siesta. They were also easy to dustproof...
#9
If 18 or 24 volt power is possible, look at some cordless power tools. Refurbed tool only prices can be good. I have an old 24 volt impact drill. 80 - 100 rpm. Can be put into rotation only. Unbelievable torque. It's green - Hitachi?
#10
... Now I must cad this...
