Go to Post Thanks to ... Dave, who teaches us not to worry, it’s only rocket science. - JohnBoucher [more]
Unread 14-08-2015, 11:20
SerpentEagle's Avatar
SerpentEagle SerpentEagle is offline
AKA: Shashank Rajesh
FRC #3641 (The Flying Toasters)
Team Role: CAD
Rookie Year: 2015
SerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to behold
Gearbox Design Feedback
Hi, I've been working on a generic drivetrain gearbox design and would appreciate any feedback.
Link to model: https://grabcad.com/library/drivebox-1-1#
Unread 14-08-2015, 11:31
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
Re: Gearbox Design Feedback
Reminds me of my favorite kids book...
-Mike
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 14-08-2015, 11:48
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
This is a great start. Granted this appears to be a single speed generic gear box, it is still a great learning step when it comes to designing gear boxes.
To Michael's point, pockets in the plates do have advantages, but there is cost associated with them.
The two most obvious advantages are: Weight saving, and they look cool.
That's about it.
Here are some of the costs associated with them: Extra design time, extra machine time, not as robust as flat plates (this point is arguable), time to clean up and de-burr.
Here is a really excellent YouTube Channel put up by 973. Adam has invested a lot of time in creating content about robot design. This includes a couple videos on transmission design and even on pocketing. One excellent point he makes is to NOT invest time into pocketing until you are absolutely certain your design is right. Trust me on this, it is excellent advice!
All that said, I also want to acknowledge your work. That trans looks really nice!
Unread 14-08-2015, 11:50
Knufire Knufire is online now
I generally try to have a solid ring of material around the outside of the gearbox, so the bolts aren't cantilevered just on the ribs. You also don't want a snap ring groove right on the output axle after the gearbox like that, it'll create a stress concentration and greatly reduce the side load required to snap the output shaft.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 14-08-2015, 11:56
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
2 points of input:
  • Gear clearance - You have the spacing between adjacent shafts set to the exact pitch diameter of the gears, which in a perfect world would work. If you add up tolerance issues with the gears, shafts, and machining precision of the plates, you could end up with gears that are "too close" and bind. Its suggested to add a little bit of extra space between shafts to compensate for that and get a smoother running gearbox. We add 0.003" between meshing gears in our transmissions.
  • Retaining ring on the output shaft - Retaining ring grooves are stress concentrators and reduce how much torque you can put through the shaft. You should try to avoid putting them in a section of the shaft that transmits power. I'd suggest looking for a different way to retain the shaft, or perhaps just move the clip all the way to the end of the shaft, past the wheel. (I'm not sure that you'd even be able to install it as pictured, since the rings don't open far enough to go over a hex shaft. An E-style clip could be installed though.)
Structurally it looks like it is strong enough for FRC applications, though I'd prefer to use larger diameter standoffs.
Unread 14-08-2015, 12:50
Team Role: CAD
Rookie Year: 2015
-Mike
XD
You're probably right, I could definitely simplify the structure a bit more.
Unread 14-08-2015, 12:57
Team Role: CAD
Rookie Year: 2015
That's about it.
Thanks for the feedback. When I was designing the plates, I actually did the "pocketing" in one sweep. All I did was lay out the holes for bearings, motors and standoffs, and then basically connected the dots. As for time, I probably would have saved an extra 15 minutes, and assuming this is water jetted, an extra 5 minutes max. I don't think 20 minutes is too much to lose.
I've actually watched many of Adam's tutorials and they were extremely helpful. You're right, I should have kept the plates generic until I am absolutely set on the design; it would be a pain in the butt to go back and make changes to the spacing without redoing all the linkages.
Thanks for your advice!
Unread 14-08-2015, 13:01
Team Role: CAD
Rookie Year: 2015
Yeah, thats how I usually do things, but I thought I would try something different this time. Your probably right though.
Also thanks for the comment on the snap rings, I have made change accordingly.
Unread 14-08-2015, 13:08
Team Role: CAD
Rookie Year: 2015
Originally Posted by s_forbes View Post
2 points of input:
I never thought about giving some tolerance spacing for the gears. I'll definitely add some on in the future.
I'm probably going to do what you said for the snap rings, just have it on the outside of the wheel. I've made changes accordingly. We've been using standard snap rings as I've done in the model without problems, but i'll defiantly look into the E-style clips.
Also the standoffs are now 1/2" opposed to 3/8". Thanks for your advice.
Unread 14-08-2015, 13:44
T^2 T^2 is offline
FRC #5499
You're gonna have a hell of a time taking those CIMs off without disassembling the entire gearbox.
Standoffs do not need to be 1/2". You have too many of them, in any case; the ones on the far right and left are completely unnecessary.
Unread 14-08-2015, 14:15
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
From what I can see, the two screws holding in the CIMs are accessible from the outside. One screw looks to be the top standoff screw, and there is a hole (in line with top and bottom standoffs, below CIM output shaft) to unscrew the other screw. Then it should be as simple as popping off the CIM gear and sliding it out of the enclosure. I could be wrong, but I imagine this was SerpentEagle's intent when designing it.
This is a nice, compact gearbox. How much does it weigh? Also, did you think about the abundance of possible pinch points where someone could get a finger stuck? I imagine it shouldn't be that hard to cover with some clear plastic (which will also help keep out scruff) but maybe you have a better idea.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 14-08-2015, 15:33
hectorcastillo's Avatar
hectorcastillo hectorcastillo is offline
Former Driver and Captain for 3481
FRC #0125 (NUTRONs)
hectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to all
The design looks really cool! One thing that I thought of is you could add two or three #8 tapped holes in a circle around the front bearing and use some button head screws to hold your bearing in place instead of a retaining ring.
365 Decontaminators (FLL) 2011 - 2012
6221 Panther Bots Alpha (FTC) 2012 - 2016
3481 Bronc Botz (FRC) 2012 - Present
125 NUTRONs (FRC) 2017 - Present
Unread 14-08-2015, 16:27
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Is that a flanged bearing? If so, you wouldn't need a retainer on this side of the gearbox if you inserted the bearing from the inside of the box.
Unread 14-08-2015, 16:46
FRC #0125 (NUTRONs)
It looks like the flange is on the outside, but yes, flipping it around would be an easier solution.
Unread 14-08-2015, 17:17
Richard Wallace's Avatar
Richard Wallace Richard Wallace is online now
I live for the details.
FRC #3620 (Average Joes)
My team has been retaining things on hex shafts by means of 1/4-20 button head cap screws and standard washers at each end. Thunderhex shaft stock makes this method very easy, because its center hole is just right for the tap. We often drive the shaft using a 1/2 inch speed wrench while holding the tap stationary. Of course this method requires us to cut shafts very close the proper length to hold whatever components are riding on them -- we use a scribe to mark them and a small lathe to face them for that.
Richard Wallace
since 2003
