Go to Post FIRST *is* about winning, and it has made many of us winners... I am glad to be a part of it. - Andy Baker [more]
Unread 12-08-2015, 18:29
jojoguy10's Avatar
jojoguy10 jojoguy10 is offline
Programming/Controls Mentor
AKA: Joe Kelly
FRC #0997 (Spartan Robotics) and FRC #2990 (Hotwire Robotics)
jojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant future
Estimated Drive Time in Dashboard
Hey CD,
Ha anyone ever tried putting an "Estimated Drive Time" in the dashboard? I think it would be cool to use at competitions to know how long the battery *should* last.
Joe Kelly
2013 and 2014 - Student (FRC#2990), Programmer (LabVIEW)
2015 and 2016 - Mentor (FRC#2990), Programming (LabVIEW)
2017-Current - Mentor (FRC#997), Controls/Programming (Java)
2015-Current - A/V Volunteer at Oregon events
Unread 13-08-2015, 10:13
TheHolyHades1 TheHolyHades1 is offline
TheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the rough
Re: Estimated Drive Time in Dashboard
I'm not sure the calculation would be a simple one, or even possible beyond very rough guesses. The problem is that depending on the way the match is played, your current draw can vary significantly, thus affecting battery life.
For example, I inadvertently left a robot idling overnight and it was still on, but the battery was down to about 6V. This was almost a 10 hour period. I would hazard a guess and say that the immediate battery voltage reading is "good enough."
Unread 13-08-2015, 19:47
jojoguy10's Avatar
AKA: Joe Kelly
Thanks for your reply!
I didn't expect it to be easy :-)
I'm hoping to maybe use this on Summer robots when we don't really have a "replace per match" basis.
Just an idea.
Unread 13-08-2015, 21:24
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
You could set a time that only runs when the joystick to move the robot is moved beyond a certain point (0.1?), and when buttons for mechanisms are held. If your mechanisms are somewhat autonomous, you could set the timer to count when the motor controllers for these objects are set to .1 or higher.
Note: You can count the amount of times a piston is used and use a seperate timer for when the compressor runs.
Last edited by thatprogrammer : 13-08-2015 at 21:25. Reason: Thought about pneumatics.
Unread 13-08-2015, 21:59
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
Team Role: Electrical
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
I've been very interested in using the current monitoring capabilities of the PDP, combined with the voltage readings and some sort of model of a SLA battery to achieve something along those lines.
There are all sorts of non-linear properties to batteries, not to mention each battery will be different, but I think it could be interesting to see how close one could get to an accurate prediciction given just the KoP electronics.
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
Unread 14-08-2015, 19:56
You might be able to simplify everything and just assume that batteries plugged in when the robot is turned on are at full charge, and then just use the current monitoring to figure out remaining charge, and apply some sort of derivative to extrapolate the remaining drive time. That might work well enough for a first guess, at least?
Unread 15-08-2015, 10:01
BenGuy's Avatar
BenGuy BenGuy is offline
Co-Driver - 3641 - Flying Toasters
AKA: Ben
FRC #3641 (The Flying Toasters)
Team Role: Operator
BenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of light
Like a car guesses how many miles until empty, that value could be dependent on the current rate of discharge that is constantly re-averaging itself as it continuously takes in more data, then the average and all data is wiped clean when robot is restarted - Just like a car.
Ben Wolak
The Flying Toasters Website
Team YouTube
Team Twitter
The real problem with computers is that they do what you tell them to do, not what you want them to do.
Unread 15-08-2015, 10:52
jojoguy10's Avatar
AKA: Joe Kelly
Great ideas! I'll have to look into them for this upcoming season!
Thanks!
P.S. I wonder if it's possible to check the current with the old cRIO system. I knw you can through the CAN network on the Jaguars. Is there a good way to basically add all of the current and use that as "total" amperage?
Unread 15-08-2015, 13:51
Well, I suggested using a full charge because apparently there's non-linearity associated with the battery voltage (unlike gasoline, I'm assuming). That said, as suggested above, a simple model of an SLA battery might do the trick.
Unread 15-08-2015, 13:53
Thanks!
You can also get the current running through each individual TalonSRX via CAN. I think the new PDB also communicates the current back through CAN, so it might be possible to just use the new PDB along with the old cRIO and get all of the current monitoring through CAN, either via the motor controller or the PDB itself?
