Go to Post But please, don't attempt to subvert the rules. It almost invariably becomes more trouble than it's worth. - Billfred [more]
Unread 16-08-2015, 00:17
hectorcastillo's Avatar
hectorcastillo hectorcastillo is offline
Former Driver and Captain for 3481
FRC #0125 (NUTRONs)
hectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to all
Re: pic: Butterfly Drive Concept
I'm actually not all that sure what the advantages are over octanum. I know that mechanums are a little trickier to code. I also know that some people just don't like mechanums for whatever reason (not really a valid argument).
I'm definitely not the best person to answer this question. I curious to see what other advantages people can think of.
365 Decontaminators (FLL) 2011 - 2012
6221 Panther Bots Alpha (FTC) 2012 - 2016
3481 Bronc Botz (FRC) 2012 - Present
125 NUTRONs (FRC) 2017 - Present
Unread 16-08-2015, 00:24
Knufire Knufire is offline
Originally Posted by hectorcastillo View Post
mechanums
Originally Posted by Mecanum Wheel View Post
Hello Mark. Mecanum is a commonly misspelled word. There are multiple ways to say it but only one way to spell it. If you have any questions, feel free to ask. Until then, you may refer to this handy chart:
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 16-08-2015, 01:02
FRC #0125 (NUTRONs)
Everything I thought I knew has been nothing but a lie...
Unread 16-08-2015, 02:10
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Originally Posted by Knufire View Post
I was hoping Mecanum Wheel would reply, but quoting "it" is just as sufficient
By the way, Mecanum AB is the company that either invented or popularized the wheel, but is nonetheless where the name came from
Unread 16-08-2015, 02:42
RoboticDaymon's Avatar
RoboticDaymon RoboticDaymon is offline
AKA: Daymon W.
FRC #2403 (Plasma Robotics)
RoboticDaymon is an unknown quantity at this point
Originally Posted by orangemoore View Post
With Mecanum you have to run each wheel individually. Here they can run each side resulting in the ability to run 3 cims per side.
Yep this is why it was designed like this. Also I wanted to ability to have a 2 speed shift with the wheels at a 1:1 ratio so this seemed like the simplest solution. Also the next iteration of the design will (probably) have the traction and omni flipped.
Unread 16-08-2015, 03:43
asid61's Avatar
asid61 asid61 is online now
AKA: Anand Rajamani
FRC #0115 (MVRT)
You do lose some functionality compared to making the traction wheel smaller, but do you think the loss pushing resistance of this drive is worth the lower gear in omni mode?
Might want to rethink that 6-cim drivetrain. The Roborio browns out so easily...
Unread 16-08-2015, 13:03
FRC #0125 (NUTRONs)
Can you explain "browning out" or share share thread that explains this?
Unread 16-08-2015, 13:19
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
Google is a great way to answer your own question, click here.
Click the first result
(2015-?): 973
(2012-2015): 955
Unread 16-08-2015, 17:51
Agreed. Software current monitoring/control, good monitoring of battery health, and a bulletproof electrical system are essential to effectively use a 6 CIM drive in a normal (i.e. not RR) game on this control system.
Unread 17-08-2015, 22:57
AKA: Daymon W.
For the 6(7) cim I agree for most circumstances it is probably overkill. if this were to be manufactured I would probably just leave a cim out of each of the 2 speed gearboxes or use current monitoring code or both. Realistically this would probably be assembled with 2 cim in each 2 speed and 1 mini cim for the center wheels.
Unread 17-08-2015, 23:44
philso philso is offline
FRC #2587
Have you designed this so that the complete butterfly module can be removed and installed as a single complete assembly or do the butterfly modules have to be assembled in the chassis? We did it the later way in 2014. It typically took an hour or more to change a wheel. 148 did it in 2014 the first way and it would take them 5 minutes or less to change out a whole butterfly module.
Unread 18-08-2015, 23:09
AKA: Daymon W.
The modules should be able to be installed as a complete assembly. They were designed to be put together outside the robot then slide into place. The only parts that might need to be assembled while on the robot are the pneumatics and the drive axles directly off the gearbox.
On a different note after some feedback from my team today there are a few different variations on the design i will be working on. I will post these revisions as soon as i finish the CAD for it.
Unread 19-08-2015, 00:08
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
Are you direct driving one of the wheels straight off the gearbox? If so, you might want to consider how hard it would be to slide the module onto the drive axle. You can't completely assemble the module separately if the gearbox output shaft is required to hold the module together. the direct driven wheel and everything floating in the module would have to line up perfectly to slide the module on. That's really annoying, especially if you're using hex. BTW, I'm assuming these things because it's a COTS gearbox.
My team had a similar design for our octocanum modules this year, and I regret not considering assembly when we designed it. I always chose to assemble half the module on the robot instead of frustratingly trying to lining up all 5 hex components.
