Go to Post Don't ever give up on your robot, especially this early in the season. That robot is what you make of it. If you give it your all, something good is bound to come your way. - Amanda Morrison [more]
Unread 19-08-2015, 00:28
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: Labview Challenge 3
I've attached my solution, includes part 1 and 3.
I wanted to play with DVRs + recursion. My only complaint with LabVIEW in this case is you cant have a DVR of a typedef in the typedef itself. You have to cast it to a different type (Int32 in this example).
For example in C you can do something like:
struct Node {
int data;
Node** children;
Instead you have to do something like
struct Node {
int data;
void** children;
and handle the proper typecast outside the typedef.
Also Bpk9p4 you picked the hardest one on my list!
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
