Go to Post We are different, on purpose, for a reason. No one in FIRST should EVER forget that. - Rich Kressly [more]
Unread 18-03-2003, 21:36
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
Exclamation Bins wrong size
Has anyone noticed at any of the competitions if the bins used differ from any bins you may have measured before ship?
My team got to Annapolis and found the bins 1/2" bigger on certain vital dimensions then they "should" have been. As a stacker, we found this to be quite disturbing.
We adjusted, I'm just wondering if they vary much from regional to regiona- I want to know if we will have to rebuild all our guide's again at Canada.
Greg
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
Unread 18-03-2003, 22:27
DaveO'B365's Avatar
DaveO'B365 DaveO'B365 is offline
FRC #0365 (Miracle Workerz/MOE)
DaveO'B365 is an unknown quantity at this point
Send a message via ICQ to DaveO'B365 Send a message via AIM to DaveO'B365
interesting...
hmmm, i didn't pay that much attention, but just a word of advice, from experience, you should allow for small discrepancies in the dimensions of the field. i could see the potential problem for a half inch difference, but there should be some safety factor in construction for these slight discrepancies. (i.e. the bar may be slightly higher/lower on different fields) i don't see how this error in the boxes could occur, since we were given a specific model number. could there have been an error in measurement or the boxes you ordered?
'like olympic medals and tennis trophies, all they signified was that the owner had done something of no benefit to anyone more capably than everyone else.' -Catch-22
'ashes and diamonds, foe and friend, we were all equal in the end'
Pink Floyd
Inspector at the Cheasapeake regional, former member of 365, and active Lil' MOE repairman
Unread 19-03-2003, 06:06
Rook's Avatar
Rook Rook is offline
#0267 (The Demolition Squad)
Rook is an unknown quantity at this point
Perhaps the bins were deformed from use?
Aaahhhhh! The atmosphere! Aaaahhhh!
(Things you might hear a meteor say.)
Unread 19-03-2003, 07:18
Johca_Gaorl's Avatar
Johca_Gaorl Johca_Gaorl is offline
Pwn3d
#0122 (NASA Knights)
Johca_Gaorl is an unknown quantity at this point
Send a message via AIM to Johca_Gaorl
Perhaps you got the wrong bins, there were bins that looked very similar to the official ones, and when I went out to look for bins, I found many of the wrong ones. There was a model number and measurements in the manual, so I don't see what could be wrong, what are your measurements you all measured?
DOX
At VT! Guess I'm unofficially part of 401 now...
Unread 19-03-2003, 07:27
John Larock John Larock is offline
#0365 (DuPont Miracle Workerz)
John Larock is on a distinguished road
Bin Size
Some team members from 639 came up to me at Annapolis and asked me if our team had any problems with the bin size. I was able to "borrow" some busted up FIRST bins and compared them to the bins Team 365 brought to test our robot with.
Although the colors were different (we purchased some inventory of a special "green" run which was still in stock after Christmas - what luck!), the models were the same. We compared the two and they were, within expected tolerances, the same. There may have been some dimensional changes due to the fact that they were severely abused by all of us teams.
Apart from that, I would say they were the same bins.
John
Unread 19-03-2003, 15:06
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
The bins we ordered back here in Ithaca, were much less wide. And yes, the bins we tested were ones we borrowed which were not deformed at the base. The question is why two bins with the same model number would be different at all in size (I'm not talking about 1/4" or less). Anyhoo, I'll go ask FIRST about it sometime.
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 19-03-2003, 15:21
Marc P. Marc P. is offline
I fix stuff.
AKA: βetamarc
Marc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond repute
Send a message via AIM to Marc P.
Perhaps thermal differences are to blame? Certain plastics are known to exhibit expansion and contraction under different temperate circumstances. In the pits or at any given working space, the temperature may be considerably colder than on stage at a competition, under bright lights and constant use.
I have noticed, in working with bins at our workspace, they are much more rigid than the ones I handled at UTC. Again, maybe it's temperature differences? It was much colder at our workspace than it was onstage.
Unread 19-03-2003, 15:32
My guess is the company that makes the bins probably modifies the mold so they can get more bins out of it. Damaged mold? No problem, just cut out the damaged part.
But we borrowed a bin from MOE and found it to be 1/4" off.
It is hard to be a stacker and take 1/4" tollerences into consideration when designing.
Greg
Unread 19-03-2003, 15:50
Pwn3d
Well, that's what you have to do then, you can't expect everything to be perfect, you gotta over-engineer
DOX
Unread 19-03-2003, 15:56
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
As for the difference in height, you should have remembered to measure the height WITH THE TOP and also, the tops could have been raised up since they were bolted on top.
g_goldman was the bin guy at Annapolis, so I'll see if he can respond to this.
robot touching a stack of bins carlye Rules/Strategy 20 11-01-2003 02:13
tipped bins cbudrecki Rules/Strategy 25 07-01-2003 23:12
How will the bins face on the ramp? Jacqui Sutton Rules/Strategy 1 07-01-2003 08:48
Is there a size regulation for the pit area if we wanted to put up a banner Ragin_Kage General Forum 6 14-03-2002 15:33
A file size issue Funkymunkey90 3D Animation and Competition 2 05-02-2002 14:50
