Go to Post Why aren't the kids who sit alongside the sidelines and observe as valued? Why are they looked upon as leeches, in it for a trip? - Madison [more]
Unread 20-08-2015, 23:11
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Re: A more autonomous teleop?
The sensors we used to automate our cube are:
Beam-break sensors, which is an all-in-one IR sender/reciever that trips anytime something reasonably reflective is in the way. The totes were plenty reflective for several inches, and using the retro-reflective vision tape will trip them from several feet away. Putting something dark and matte behind the sensor (or just lots of open air) keeps them from tripping falsely.
We also use hall-effect sensors (can find at WCP) which detect when a magnet passes in front of it. Our tote lifter was on a chain run, and we mounted a magnet to one link of chain, and placed beam-breaks at the top and bottom in the necessary positions. The stacker simply lifted until the sensor tripped and lowered until the other one tripped.
Both these options are great because they work without contact. We found using mechanical limit switches can be tricky as they can bend over time and the positioning changes. Without contact the sensors aren't going to move, heck all of our sensors were simply Velcro-d on, so we could manually adjust them if necessary.
Unread 20-08-2015, 23:37
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Do you have a part # for this guy? Curious what you guys used.
Thanks!
R.C.
MadTown Robotics Team 1323
Unread 20-08-2015, 23:45
Jacob Bendicksen's Avatar
Jacob Bendicksen Jacob Bendicksen is offline
Figuring out what's next
Jacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond repute
If you're interested in automation, I'd highly recommend taking a look at 4488's robot from this year. Completely automated other than driving and picking up cans - I loved it.
jacobbendicksen.com | @jacobbendicksen
Yale University Class of 2020
Team 1540 | 2012-2016
7 Chairman's Awards, 6 other awards, 2015 Dean's List Finalist, 1 event win, 2 finalist finishes. Thanks for an amazing ride.
Unread 20-08-2015, 23:58
Knufire Knufire is online now
Thanks!
Sensors with similar functionality were included in the 2011 KOP, Rockwell Automation 42EF-D1MNAK-A2. I know 469 uses some sligthly smaller units from Allen Bradely. 5188 got a few from AutomationDirect this season. I know some teams have had luck getting them ultra cheap from China on Ebay.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 21-08-2015, 00:06
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
we added a limit switch to detect when totes entered the bot at worlds... It would then stack them as they came really fast! Using the 1114-like ramp at school we were able to stack 6 totes in about 10 seconds instead of 22 when doing it manually.
I would also recommend adding sequences you use often to your controllers, as it will be more consistent and save time(like flipping RCs or dropping the yellow totes on the step)
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 21-08-2015, 00:11
jajabinx124's Avatar
jajabinx124 jajabinx124 is online now
Team 2052 Alumni
AKA: Kshitij Wavre
jajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond repute
Team 2052 used a photo switch sensor for our robot this year, which is a sensor that detects the presence or change of light, and used it to detect whether a tote was ready to be lifted by our lifting mechanism or not (the light would change when the tote was ready to be lifted up).
We had an override for that sensor in case it didn't work.
FRC Volunteer CSA (MRI off-season event, 2017 Lake Superior Regional, 2017 10,000 Lakes Regional) 2016 - Present
FRC 2052 KnightKrawler (Team Captain, Strategist, Scouting, Programming) 2013 - 2016
1 Division Win & Einstein Appearance
3 Division Quarter-Finalists
1 Regional Chairman's Award
5 Regional Wins, 3 Regional Finalists
3 MN State Championship Wins, 1 MN State Championship Finalist
Thanks to all our alliance partners who krawled with us: 41, 70, 225, 525, 1595, 2054, 2062, 2122, 2175, 2227, 2472, 2526, 2883, 2990, 3018, 3244, 3276, 3310, 3313, 3360, 3538, 3692, 4011, 4198, 4536, 4607, 4778, 5172, 5690
Unread 21-08-2015, 00:14
Drive Coach
AKA: Antoine L.
You don't want to learn about this the hard way
Unread 21-08-2015, 00:21
1197 carried an ultrasonic sensor inside one of our intake arms. If something was detected, the arms would snap shut and the wheels would pull whatever was in there into the robot until it hit a pair of heavy-duty limit switches (or rather, their trigger plates). A bit of sensor magic on the lift and we had a pretty fast stacker.
Unread 21-08-2015, 09:46
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
As no one has mentioned it yet I figure I will add a bit of warning against over-automating.
Automating robot tasks can be a really powerful tool as long as it is used appropriately. Be careful of automating too many tasks though or tasks that rely on a lot of different variables.
I'll give an example; in last year's game we realized that our ball-pickup mechanism was rather slow so we decided to automate a lot of the process. The operator would hold down a button to drop our grabber and turn on our intake roller and then release the button to stop the roller and return to a "carry" position. In general it worked well but would occasionally cause us to have problems if the ball was falling out of our grabber, if we didn't approach the ball straight-on, or even if we were getting defended while trying to pick up. Basically it gave our drivers even more tasks to be mindful of (making sure to kill the automation if it was going to make us drop the ball or miss the ball, etc.)
Even worse was that on occasion a bug would crop up where the automation could not be interrupted. It took us a long time to catch what the issue was because it was so intermittent and in the meantime we would drop a ball and have to wait while our pick-up moved to "carry" position and then all the way back to "pick-up" position. It was pain and we looked pretty bad on the field.
I think it was in one of 254's publications that they said automation is best used for tasks that a human cannot do efficiently, or that a computer could do more efficiently. Stacking totes in this year's game lended itself to automation. If a tote was fully inside your gripper (as detected by sensors) then it was likely that you were going to be able to lift it.
In our situation automation didn't really speed anything up. We still had to wait for the grabber to move between pick-up positions and the grabber itself either needed many more sensors to be sure the ball was captured or needed the operator to visualy verify that the ball was captured.
Unread 21-08-2015, 10:19
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
A lot of teams automated their pick ups in 2014. I think what might have not been done in this case was designing with that automation in mind. Perhaps you could have optimized it more by adding a beam break to tell when the ball was in, and made the intake go back to 'carry' by itself?
My point is: Automation should be considered during the design process, doing it too late is often sloppy.
Unread 21-08-2015, 10:32
Monochron's Avatar
Engineering Mentor
We did use a sensor to tell us when the ball was in, but that didn't eliminate the problem of the ball unseating itself, getting defended against, or otherwise losing grasp while going back to "carry". A more complete solution would have to constantly react to the current state of the ball throughout the back-to-carry maneuver, because the likelihood of losing the ball with our grabber was too high.
My point was that the way we designed our ball carrier didn't match the automation we tried to use, not that automation shouldn't be done on ball pick-ups. Because our back-to-carry maneuver was so slow (on the order of couple seconds after first acquiring the ball) automating that portion made no sense.
Unread 21-08-2015, 10:06
Chirag's Avatar
Chirag Chirag is offline
Alumni, now Remote Mentor (?)
AKA: Chirag Patel
FRC #4761 (Robockets)
Chirag is an unknown quantity at this point
4761 used several photoelectric sensors donated by Rockwell Automation to automate our tote loading at the human player station. Our robot was basically made of two conveyors, one being able to move up and down along extrusion rails to reach different heights, the other being stationary on the bottom of the robot. We had a break-beam emitter and receiver pair at opposite sides of the moving conveyor to detect when a tote was completely on the conveyor, a few diffuse sensors along the extrusion to detect different heights for the conveyor to move to, and another break-beam set on the main conveyor at the ground level of the robot to detect when a tote was completely off of the moving conveyor. All our operator did was press and hold a button while we were at the chute and the robot loaded the totes for us slightly faster than our human player could send the totes through the chute.
Here's a video of the whole routine in action
We also tried automating the moving conveyor to move to the top of any stack with the press of a button using one of the diffuse sensors to make for quicker stacking/ capping but it wasn't as reliable as we wanted it to be.
Our robot didn't have these sensors originally and each component was manually moved by the operator. After we added these features between districts, I was amazed by the power of automating features in the robot. In my opinion, we went from being one of the slower robots to being able to keep up with most of the robots at the competitions we attended.
_______________________________________________
The Robockets 4761
Student (2013 - 2015), Mechanical Lead (2014), Tech. Co-President (2015)
2014 - RIDE Winners (with 125 and 78)
2013 - Boston Regional Rookie All-Star and Highest Rookie Seed
http://www.robockets.org/
https://www.facebook.com/FrcTeam4761
https://www.twitter.com/FRC4761
Unread 21-08-2015, 00:19
I am Dave! Yognaut
AKA: Brian Bray
Thanks!
We used Optek OPB720B
