Go to Post I don't care what the team numbers said, on Friday there were no rookies there. - Taylor [more]
Unread 21-08-2015, 09:38
stopyourself stopyourself is offline
FRC #2335 (Sargon)
stopyourself is on a distinguished road
P27 Gearmotor
Hello,
My mentor told me to ask if this motor, the P27 Gearmotor with backshaft http://www.andymark.com/product-p/am-0915a.htm ran at similar speed/torque while running backwards. He could not find the information online, does anyone know?
2013-2016: Team 2335
Unread 21-08-2015, 10:04
Knufire Knufire is offline
Re: P27 Gearmotor
Within a margin of error, yes.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 23-08-2015, 08:59
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: P27 Gearmotor
Yes, both the motor and the gearbox are symmetrical. I can't think of any motors or gearboxes in common FRC usage that have a systematic bias. If they did, it would require some interesting gearing to use them in a skid-steer drive. In the normal configurations, driving forward requires the motors on the opposite sides to spin in opposite directions.
Unread 23-08-2015, 18:13
Re: P27 Gearmotor
While I agree that current FRC motors do not have a bias, this wasn't the case at the turn of the century. By far the most common drive motor was from a drill, which did go faster clockwise. Given a little bit of time at the sticks, humans learn to compensate really well.
Unread 23-08-2015, 20:47
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
Team Role: Electrical
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
Re: P27 Gearmotor
The only non-symetric motor that I can think of are the window motor/snow blower/van door style motors. I can't visualize how the mechanics of it would change their characteristics in CW or CCW but I'd be curious to know if anyone has tested/has any data on this.
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
Unread 23-08-2015, 22:17
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: P27 Gearmotor
In directionally biased motors, the angles at which the coils are switched on and off are optimized for one direction. this leads to degraded performance in the opposite direction. In unbiased motors, performance is degraded equally in both directions since it isn't optimised for either direction.
The drill motors used in most drivetrains prior to 2005 had a CCW bias when viewed from the the shaft end. This is because most drill bits are designed to cut in that direction. As a result, it was common to see the drive motors mounted on the inside of one side and the outside of the other. This allowed the motors on both sides to turn in the same direction (and thus provide similar amounts of power) while driving straight forward.
Last edited by PAR_WIG1350 : 23-08-2015 at 22:18. Reason: Separated paragraphs for readability
