Go to Post You can sometimes step outside the box if you have properly thought through the question. - Jim Zondag [more]
  #31   Spotlight this post!
Unread 27-08-2015, 22:02
Jared Russell's Avatar
Taking a year (mostly) off
Re: Unusual, potential game pieces
Originally Posted by Wayne TenBrink View Post
I have been hoping for a cylindrical game piece for years. Capped and half filled would be an interesting challenge, but I would prefer to see thin walled, hollow tubes. Length, diameter, material, weight, and quantity TBD. The length-to-diameter ratio should be near 1:1. This would make it feasible to acquire the tube by several methods (grasp OD, skewer the bore, etc.) with no obviously "correct" method. Game pieces could lay on their side or stand on end, and the orientation of the robot to the game piece would affect the way the tube reacted during acquisition. There is a broad range of tasks options to challenge teams with different skills, and few robot mechanism ideas from previous games would be useful. Game piece placement options include: (easiest) move it into a defined scoring zone, (easy) place in bin, (moderate) toss it into a bin that is higher than the robot, (harder) hang it on a pin rack with more points for higher pins, or (harder yet) fit the game piece through a round hole with modest clearance to the tube OD for highest points. Color coded tubes? Different size tubes? Moveable goals? Options galore! Tubes could be cheap and readily available (PVC), robust, visible from the stands, wouldn't require inflation, and would fit thru a door.
Best idea in the thread
  #32   Spotlight this post!
Unread 27-08-2015, 22:30
I, too, have been hoping for traffic cones.
That being said, we haven't had playground dodgeballs in a long while, probably due to the "inflatable" and "consistent characteristics" problems.
  #33   Spotlight this post!
Unread 27-08-2015, 22:47
holygrail's Avatar
holygrail holygrail is offline
Gavin Wood
FRC #1939 (The Kuhnigits)
holygrail is just really niceholygrail is just really niceholygrail is just really niceholygrail is just really nice
Hula hoops could definitely present an interesting challenge. We invented a VEX game with foam rings and tall posts and teams got extra points for having the top ring on the post. It was probably my favorite game we have used for our VEX classes because it always kept the action moving around since teams were incentivized to score on a different post each time. Hula hoops would be an easy way to do something similar for larger FRC bots.
I also think the cylinder idea would be awesome. The GDC likely takes into account transportability, so I could see them using something like that but maybe more like a cone. They would stack for easy transportation and field reset and they would add the extra challenge of not rolling straight.
  #34   Spotlight this post!
Unread 27-08-2015, 23:18
Big Ideas Big Ideas is offline
AKA: Stephen des Jardins
FRC #2102 (Team Paradox)
Big Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant future
I'm still holding out for FIRST using these for game pieces.
YES!! Bumble Balls are the best! Robot gets extra points for turning them off when in possession. I figure about 50 on the field would be a gas.
  #35   Spotlight this post!
Unread 28-08-2015, 00:01
jajabinx124's Avatar
jajabinx124 jajabinx124 is offline
Team 2052 Alumni
AKA: Kshitij Wavre
jajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond repute
Originally Posted by The other Gabe View Post
our most used robot for demos is by far 2012
Same with us, 2012 is pretty much our go to demo bot. (We try to use 2013 and others but it's a bit risky. The frisbees could break things or hurt someone, so we have to be extra careful when demoing 2013) Also we don't have to worry about accidentaly hitting other people with 2012 game pieces.
FRC Volunteer CSA (MRI off-season event, 2017 Lake Superior Regional, 2017 10,000 Lakes Regional) 2016 - Present
FRC 2052 KnightKrawler (Team Captain, Strategist, Scouting, Programming) 2013 - 2016
1 Division Win & Einstein Appearance
3 Division Quarter-Finalists
1 Regional Chairman's Award
5 Regional Wins, 3 Regional Finalists
3 MN State Championship Wins, 1 MN State Championship Finalist
Thanks to all our alliance partners who krawled with us: 41, 70, 225, 525, 1595, 2054, 2062, 2122, 2175, 2227, 2472, 2526, 2883, 2990, 3018, 3244, 3276, 3310, 3313, 3360, 3538, 3692, 4011, 4198, 4536, 4607, 4778, 5172, 5690
  #36   Spotlight this post!
Unread 28-08-2015, 02:17
SavtaKenneth SavtaKenneth is offline
AKA: Yotam Kenneth
FRC #2212
SavtaKenneth will become famous soon enough
About using pipes as a game piece. In Israel we hold each year a preparatory competition for teams called Falafel, this gives team a chance to practice another (more laid back) build season. Last year our game piece was PVC pipes and it was a great success for the following reasons
  • Very cheap
  • very easy to find
  • Can handle rough contact from robots
  • New challenge for FRC teams but it does have a few known solutions in the outside world
We got great feedback from teams about this game piece and it'd be pretty cool if FIRST used a similar game piece in the future.
If anyone is interested here are some videos from the final matches of the competition (The goal was to move as many pipes to the goals on the other end of the field and then hang during the end game)
https://www.youtube.com/watch?v=mpn_...DdAEER10c1ejz9
2012-Present Referee
2014 & 2015 Israel Regional Volunteer of The Year Award
2212 alumni
  #37   Spotlight this post!
Unread 28-08-2015, 05:28
Koko Ed's Avatar
Koko Ed Koko Ed is online now
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
We used our 2013 robot for demos at the Monroe County Fair. There were many children injuries (many from them doing brutal things to one another chasing down frisbees) and one very scary moment where an eager toddler try to frontload the robot just before it fired and the launch was quickly aborted.
  #38   Spotlight this post!
Unread 28-08-2015, 08:02
foote stepped in
AKA: E. Foote
FRC #0868
I'm still in favor of a heavy game piece greatly changing a robot's dynamic. Most teams assume year in and year out that their robot will weigh 150ish lbs fully loaded, but if the game requires the robot to pick up and drop off 50-100 lbs of game items, drive trains will really require some thought, as well as manipulators.
Also the biggest crowd pleaser in recent game history was the bridges from 2012.
Heavy game object which can be un-scored + requirement to balance with game objects + robot v robot interactions would be awesome.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
  #39   Spotlight this post!
Unread 28-08-2015, 08:18
hectorcastillo's Avatar
hectorcastillo hectorcastillo is offline
Former Driver and Team Captain
FRC #3481 (Bronc Botz)
hectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to all
Originally Posted by chrisfl View Post
American footballs
Another "good game piece" criterium: NOT inflated.
I think the New England teams would have an advantage in this game
365 The Decontaminators (FLL) 2011 - 2012
3481 The Bronc Botz (FRC) 2012 - Present
6221 Panther Bots Alpha (FTC) 2012 - 2016
As a FIRST Alum, it's nice to be able to eat dinner again. That is, until I get off the meal plan and have to start feeding myself.
  #40   Spotlight this post!
Unread 28-08-2015, 09:34
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Please, in the name of Kamen, no.
We've already got gigantic tetrahedrons, trackballs, yoga balls, innertubes, basketball goals, and recycling cans taking up space in our workshop. Please no more enormous, useless game objects.
Hi!
  #41   Spotlight this post!
Unread 28-08-2015, 09:41
Noudvanbrunscho's Avatar
Noudvanbrunscho Noudvanbrunscho is offline
Scout mentor
FRC #4481
Noudvanbrunscho is a jewel in the roughNoudvanbrunscho is a jewel in the roughNoudvanbrunscho is a jewel in the rough
Maybe u can use the traffic cones to fence the old game pieces?
2015 - Team Spirit Award (Tesla-Archimedes Division)
2015 - Engineering Inspiration (Virginia)
2015 - Finalist (Virginia)
2014 - Imagery Award (Newton Division)
2014 - Engineering Inspiration (North-Carolina)
2013 - Rookie All-Star (North-Carolina)
Forty fooouuuuurrrr --- Eighty ooooooonnnnneeee!
  #42   Spotlight this post!
Unread 28-08-2015, 09:58
TDav540's Avatar
TDav540 TDav540 is online now
Questionable Decisionmakers
AKA: Trevor Davidson
FRC #1648 (G3 Robotics)
TDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud of
Well at least the recycling can you could repurpose
2015-??: FRC 1648, G3 Robotics
2016 Carver Division, Columbus District Chairman's Award, Albany District Finalists
Georgia Tech, Class of 2019; Emcee, Ref, and 2016 Technology Enrichment Presenter
2011-15: FRC 540, TALON 540 Godwin Robotics
Proud Alumnus and Supporter
2015 Newton Division, Virginia Regional Finalist Alliance Captain
2014 Curie Division, Virginia Regional Engineering Inspiration
2013 Curie Division, Virginia Regional Engineering Inspiration
  #43   Spotlight this post!
Unread 28-08-2015, 10:16
marshall's Avatar
marshall marshall is online now
FRC #0900 (The Zebracorns)
This happened a few times to us this past season unintentionally. Had to have a student clean it out at one point.
  #44   Spotlight this post!
Unread 28-08-2015, 10:28
Data Nerd
FRC #0079
You know the track balls, yoga balls, and inner tubes can be deflated right?
  #45   Spotlight this post!
Unread 28-08-2015, 10:31
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Why haven't you disassembled your tetras by now? Do you still do demonstrations with your 2005 robot?
