Go to Post CAD pictures are cool, but hardware in hand is cooler. :) - ajlapp [more]
Unread 28-08-2015, 12:59
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
fovea1959 will become famous soon enough
spud gun/T-shirt gun valve
The team took on an off-season project that includes a T-shirt gun. It's all working, but the range is a little short. We're using a sprinkler valve to shoot (Rainbird, I believe), shot tank is going to about 50-70 PSI...
One of the students in town from another team with spudgun experience thinks that part of the problem is that the stock valve does not open quickly enough, and suggested making one of the mods commonly seen on youtube; it appears that the mods involve not actuating the valve with the solenoid, but venting the back side of the diaphragm to atmosphere to snap it open. The problem there is that you need a smaller valve to open the back side; the examples on youtube are all manually actuated.
Has anyone done a sprinkler valve mod, but kept things under computer control? I think I know how to do it using a FESTO or SMC to vent the back side, but I sure don't want to reinvent any wheels. ("I'm a programmer, Jim, not a design engineer....")
Unread 28-08-2015, 13:39
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: spud gun/T-shirt gun valve
Stop right there!
Do not use a plastic sprinkler valve (designed for water) to switch air pressure. When the valve fails, it will explode and fragment, making this a serious safety hazard.
We used a valve similar to this for our air cannon (we used a 3/4" version). Note that it is rated for air as well as water.
For the same reasons, do not use PVC or similar plastic pipes to carry air pressure.
Also, in general, larger valves will allow you to get more kick out of a given air pressure. A good rule of thumb to start is to have the valve (and all plumbing from the air tank to the barrel) be at least 1/3 the diameter of the barrel.
Unread 28-08-2015, 13:44
fovea1959's Avatar
AKA: Doug Wegscheid
so what did you use for barrel and 1/3xbarrel diameter tubing?
Unread 28-08-2015, 13:58
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
We originally had a 2" i.d. barrel and 3/4" port valves. We increased later to a 3" barrel, which helped with the footballs we were launching by reducing friction, but did not really increase the flight length of t-shirts that we had to roll "larger" to fit. We believe this is because the air flow rate was limited by the valve. Our calculations show that we could get better range if we went to 1" valves, but we haven't tested this out yet.
We also figured out how to roll t-shirts to shoot in the cannon that requires no tape, thread, zip tie, or other binding. Lots of other good tips in that thread.
We're in the process of improving for upcoming football games. A picture of the current cannon (taken Monday evening) is here. We did not change the barrels out for metal yet, but will do so before making the switch to 1" valves. We definitely do not have any PVC upstream of the valve. We've added a speaker this year, new wheels, steerable turret, LEDs, and are working on a cowling that will make it look more like a tank.
Last edited by GeeTwo : 28-08-2015 at 14:16. Reason: Added link to current picture.
Unread 28-08-2015, 14:13
Monochron's Avatar
Monochron Monochron is online now
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
What kind of range are you getting with that? We got up to around 300 ft. with that same valve and proper weighting of our payload.
I'll agree with GeeTwo though, you should go with a higher rated valve for safety reasons.
Unread 28-08-2015, 14:41
fovea1959's Avatar
AKA: Doug Wegscheid
Originally Posted by GeeTwo View Post
Stop right there!
Why is running air at 70PSI more dangerous than running water at 70PSI?
Unread 28-08-2015, 14:50
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
We just use a large solenoid. The back release valve is unnecessary, in our experience.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 28-08-2015, 14:53
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
This is no different to using the Clippard air tanks or most other FRC actuator (electric or pneumatic) Exceed specifications and you're gonna have a bad day.
Standard water mains operate around 55-75 psi, but reach as high as 100 psi, and sprinkler valves have to be designed to function in any regional pressure condition, with safety overhead for manufacturing tolerance reasons and otherwise. Since the valve will handle 100 psi and could likely handle 120, I don't think 50-70 could be an issue.
Heck, when a sprinkler valve closes, it has to absorb all of the inertia in the flowing water as well. That just means more pressure it has to be designed to handle.
I realize that the valves aren't air rated, but that really just means nobody tried. The principle behind pressure in compressible air and incompressible water is different, but the forces at the valve are the same (psi). There is no reason it would explode at those pressures, water or otherwise.
TL;DR, if you put 300 psi behind it, yeah it will probably explode, and yeah you would get hurt. But at 70 psi, I wouldn't be worried.
Unread 28-08-2015, 15:04
D.Allred's Avatar
D.Allred D.Allred is offline
FRC #4451 (Rat Rod Robotics)
D.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond repute
Air is a compressible fluid. Water is not. Rapid expansion of compressed air when released will turn debris into shrapnel. Do not use any valve unless it is rated for compressed air.
David
Unread 28-08-2015, 19:50
DonShaw DonShaw is offline
FRC #1261
DonShaw is a glorious beacon of lightDonShaw is a glorious beacon of lightDonShaw is a glorious beacon of lightDonShaw is a glorious beacon of lightDonShaw is a glorious beacon of lightDonShaw is a glorious beacon of light
Here is the Robo Lions Team 1261 T Shirt Bot
http://prhsrobotics.com/outreach/tshirtbot/
Uses 3/4" air solenoids with duel stage pressure reduction from a 3000 psi scuba tank. All barrels are encased in 1/2" poly carbonate and are 3" in diameter which are polycarb as well.
Unread 29-08-2015, 09:38
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
There are those who will tell you that 70psi air pressure is more likely to cause a rupture than 70PSI of water pressure at the time of switching. I don't disbelieve their arguments, but the much more compelling argument to me is this: Air at 70psi has a lot more energy than water at 70psi. That is, should the thing rupture, there's a whole lot more potential for damage.
For scale purposes, I shall use a single FRC Clippard tank (574 ml). I shall also simplify the problem to assume that everything is at the same temperature, 0C. It's a bit colder than the typical FRC playing field, but if you increase the temperature or recognize that air compressors heat the air up as they go, the situation only gets more dangerous.
Acknowledging the hazards of info from Wikipedia, and promising that I will verify them against the CRC Handbook on Monday when I get back to the office:
Originally Posted by wikipedia page for "Properties_of_water"
The compressibility of water is a function of pressure and temperature. At 0 °C, at the limit of zero pressure, the compressibility is 5.1×10−10 Pa−1.[31] At the zero-pressure limit, the compressibility reaches a minimum of 4.4×10−10 Pa−1 around 45 °C before increasing again with increasing temperature. As the pressure is increased, the compressibility decreases, being 3.9×10−10 Pa−1 at 0 °C and 100 MPa.
...The low compressibility of water means that even in the deep oceans at 4 km depth, where pressures are 40 MPa, there is only a 1.8% decrease in volume.[32]
70 psi is equal to 483 kPa (from google units, but agrees well with my understanding that 1 atm ~ 14.2 psi and also ~ 105 Pa).
Finally, recall that Energy is the ability to do work, so let's caculuate how much work each can do:
Let's assume that compressibility scales linearly with pressure over the range given for water. This means that at 70 psi, the compressibility at the end point is: (5.1 - (5.1 - 3.9) * 0.483 / 100) * 10-10Pa-1 ~ 5.095 x 10-10Pa-1. This is very little change (much less than the implied resolution), so I'll use a constant 5.1 * 10-10Pa. This means that a clippard tank full of water at 70 psig which is allowed to expand to ambient will increase by about 574 ml * 5.1*10-10Pa-1 * 483 kPa = .141 ml (or about 1/7 of a cubic centimeter!). If it were pushing a piston it would do .141 ml * 483 kPa / 2 = 34 lPa = 34mJ, or .034 joules. For those who think in English units, a joule is about three-quarters of a foot pound, so this would lift one pound about 5/16 of an inch.
Now, let's do the same thing with air. To keep the math simpler, I'll assume that the temperature remains constant. Then, as we are talking about the same mass of air, we can use Boyle's Law, which is that PV = constant. For Boyle's Law, we must use total pressure, so that our end pressure is 1 atmosphere, or 101 kPa, and our starting pressure is 483 kPa + 101 kPa = 594 kPa. Our initial volume is again 574 ml. We have: 574 ml * 594 kPa = V * 101 kPa. Solving for V, we get 3370 ml. That is, the gas expanded by 2800 ml, or nearly three quarts. Because the pressure does not decrease linearly with volume, the average force is not just half the initial force, but a bit less. The work that can be done by this expansion is 332 l kPa, or 332 J. In English units, this will lift one pound about 244 feet!
In the actual case of an exploding tank or valve, the temperature will not remain constant. The rapidly expanding air will cool, decreasing the pressure and therefore the amount of mechanical energy released. Air is about 40 percent more compressible in the isothermal (constant temperature) than in the adiabatic (constant entropy, or very rapid) case. This means that the actual amount of energy released will be closer to 150 foot-pounds, but there's still five orders of magnitude more energy in the air than the water.
Unread 29-08-2015, 12:21
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
I recommend these valves. http://www.airbagit.com/Brass-Air-Va...irvalve-06.htm They are made of brass, rated for 300psi of air pressure, open quickly and are easy to modulate. Plus they are designed to be able to replace the diaphragm. http://www.airbagit.com/Air-Valve-Di...irvalve-16.htm
You can use a couple of them if you need more flow. We used them on my previous team when playing around with a t-shirt cannon and you could adjust the distance based on the length of the electrical pulse to the coil because they were so quick acting. In our case we used 4 which fed 4 ports on the back of the barrel. We did play around with only activating 2 solenoids at a time and the performance was adequate at that level in my opinion.
Unread 29-08-2015, 13:15
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is online now
Mad Scientist
AKA: Me
FRC #2040 (DERT)
This is a commonly asked question. and the reason is 2 fold:
1st is the compressibility of air vs the incompressibility of water. This means that when a vessel holding pressure water ruptures, all of the pressure is relieved with only a small fraction of expansion ( IE pushing of the shards). When a vessel holding air ruptures, the pressure is released over time carrying debris with it.
2nd is the failure mode of most plastics. When brittle objects rupture (such as PVC) the failure mode is to create shards that are sharp. Since air does not relieve all the pressure at once, it carries these shards with it as it expands to fill the 'new' area (relieves the pressure). This creates high velocity sharp projectiles .
Believe me when I say there is VERY GOOD REASON that most plastic volumes carry the warning that they are only pressure rated for liquids (take it from someone who has seen this up close ... and is lucky enough to still be here).
___________________
- Tennyson, Ulysses
Unread 29-08-2015, 17:11
Just to further explain the danger of compressed air:
A sufficient volume of air at single-digit IWC (Inches of Water Column) can, if released suddenly, make its presence known throughout a brand-new building (by shaking if I recall correctly) with the building's biggest door wide open to vent any sudden releases of air straight outside. I wasn't in that building at the time--but I heard about it.
1 IWC = 0.036 PSI per Google's converter (I rounded).
And the item containing said air was, in fact, rated for gases.
Unread 29-08-2015, 21:48
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
We use an Asco 2/2 series main pulse valve. 8353C035. It is intended for back pulsing dust collectors. High flow rate & fast acting.
