Go to Post NEMO is a virtual organization with a virtual headquarters and virtual bank account. - KathieK [more]
Unread 03-09-2015, 00:46
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
Re: Bevel/Miter Gear Mounting Distances
When designing these you will need to have the bearing flanges on the miter/bevel side to take the axial load into the structure. I would also recommend a thrust bearing, an Oilite bronze bearing is ideal for this application. The Bearing Flange is 1/16" thick, and the Oilite Bearings are normally 1/16" thick in this size range. So make sure to account for another 0.125" behind each gear.
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
