Go to Post Rules arent built around robots. Robots are built around the rules. - dodar [more]
Unread 02-09-2015, 22:37
vigneshv vigneshv is offline
FRC #2489
vigneshv is on a distinguished road
FRC Toolchain in OS X El Capitan
I have the developer beta of OS X El Capitan installed, and found that the FRC Toolchain does not work. I think this is primarily due to system integrity protection/rootless, but I am not 100% sure. Has anybody gotten the toolchain working on El Capitan yet? I'd prefer not to disable system integrity protection.
Unread 03-09-2015, 11:22
CodeYeti's Avatar
CodeYeti CodeYeti is offline
FRC Addict
AKA: Matt Coffin
CodeYeti is an unknown quantity at this point
Re: FRC Toolchain in OS X El Capitan
Which FRC toolchain are you referring to? I'll assume you're talking about C++ as that's probably the one causing issues with a rootless environment.
First, I don't know why you'd want to keep System Integrity Protection unless you don't trust yourself. To me, it seems to be more of a "users are dumb and need to be protected from themselves" feature.
As far as workarounds, you could try putting the toolchain somewhere in your home directory. I'm not sure how the FRC official one works, but you can take a look at the debian packages here or my homebrew packages to get an idea of how to build it from source yourself if need be.
Lastly, homebrew by default will chown /usr/local to your user so that it need not be run with sudo every time. This means that, once installed, it might work with System Integrity Protection enabled. That said, installing it would probably require it to be disabled.
Personally, I would just disable it, so long as you trust yourself to be an administrator on your own computer.
Best of luck, let us know how it goes.
EDIT: You can also change the default install path for homebrew to be within your home directory, so if it doesn't work out of the box, that would be my go-to option; change homebrew's install path to somewhere in your home directory and use my homebrew ports to install the toolchain.
Team 662 - Student/Programming VP/Driver - (2011-2013) - 43-31-2
Team 662 - Mentor - (2015-present) - 0-0-0
Unread 24-10-2015, 13:57
DiverJim DiverJim is offline
Lead Mentor Team 442
FRC #0442 (Redstone Robotics)
DiverJim is an unknown quantity at this point
If your not on the Beta Test teams, is there a way to install the tool chain? I'm trying to teach a few teams C++ in my area and stupidly updated last night and now I'm hosed...
Thanks
Jim
Unread 27-10-2015, 12:57
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Unless you want to disable system integrity mode, no.
If you don't mind disabling system integrity mode, then that should work: http://www.macworld.com/article/2986...l-capitan.html
Watchdog.Kill();
