Go to Post The Tesla came in the blue tote. This is why you should always inventory your KOP before the replacement window closes! :p - sparrowkc [more]
Unread 04-09-2015, 14:30
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: need suggestion for power distribution for mule board
Google "MAXI fuse block". These are popular for after market large stereo systems. We used the Stinger 4-position block on our air cannon back when four 40A circuits was enough. We ran another automotive blade fuse box for the smaller circuits. We had these two in parallel with each other behind the 120A main breaker. No issues to report.
