#16
Re: Bearings vs Bearing Blocks
And no, I did not search "bearing block" in google images. |
#17
Assuming you don't have a CNC handy, drilling 1-1/8 bearing holes in thin aluminum (<1/4") a step drill works well. You can pilot drill a small hole through the channel to locate the step drill. You don't the spring back or grabbing that you get with a twist drill. For anything under .1" I would recommend a doubler plate to get more thickness.
What I like about the VEX bearing blocks
The biggest disadvantage is there are a lot more expensive. |
#19
We got one of these a couple of years ago. A bit fiddly but does an accurate hole through a single sheet or stacks of custom bearing blocks. At $70 don't know why I didn't buy it ages ago.
http://www.busybeetools.com/products...ank-arbor.html |
#20
#21
Sorry for messy link and brevity, on my phone. The tool is held in a mill.You can adjust the offset of the boring bar (cutter) to get a precisely dimensioned hole. Last edited by Steven Smith : 09-05-2015 at 11:44 PM. |
#22
They will not work in a drill press, however. Not tight enough. It depends on the rigidity of the mill quill. Last edited by asid61 : 09-06-2015 at 12:43 AM. |
#23
And no, we don't have a mill. I've never actually seen a mill (or if I have, I didn't know it was a mill). |
#24
If you don't have a mill you might want to give this a try:
http://www.trick-tools.com/Slugger_S...inch_SM112_402 Note that you also need to buy the arbor (http://www.trick-tools.com/Slugger_S...rbor_18255_449) too. I have not used one myself, and can't find out how accurate a hole they make. My guess is "good enough", especially for a team working with simple tools. [Update: one site says 0.0005!] Step drills in thin (0.60-0.125) material doubled up and rivetted together could be another solution for you. Last edited by JCharlton : 09-06-2015 at 11:14 AM. |
#26
Hole saws and similar hole cutters can get you a hole close to 1.125", but it's going to be inaccurate, both in size and in center position. Probably good enough position for an intake roller or something, but not good enough for a gearbox or exact centers on a drivetrain. The real problem is size though - you're going to have a really loose fit on the bearings, and they'll easily fall out. Bearing holes are almost always a circumstance where precision is warranted.
#27
Tensioning is the primary reason for using bearing blocks (or wheel trucks, or whatever you want to call them). There are a number of ways to tension your chain/belt/whatever in your drivetrain, but in my mind bearing blocks are far and away the best solution.
Solution 1: exact center to center design. I think this is what the OP is referring to in terms of "just drilling a hole," but if it was, he left out a lot of the necessary detail. Basically, you design holes into your DT frame that are exactly the diameter of your bearings, at exactly the right distance apart to keep your drive belts/chains perfectly tensioned. Advantages: low part count, lighter, simpler. Low maintenance (potentially). Disadvantages: very tight tolerances. You need to get bearing holes to withing -.002/+.000 IIRC (it's been a while) to get a good fit, and center to center distances probably need to be +/- .005 for belt and +/- .01 for 25 chain. (It's been a while, and I'm mostly pulling these numbers out of my behind, but these should give you an idea of the tolerances required.) If you get it wrong, you have to remake everything. Generally harder to assemble and to maintain if it breaks. It often requires a heavier drivetrain, as you must use .125" tubing to properly support the bearings instead of much lighter .0625" tubing. Getting an efficient system is pretty hit and miss. Solution 2: Tension the belt/chain without sliding a bearing. You can put an idler in to change the chain path and adjust the tension by changing the position of the idler. You can also physically change the length of the chain belt by putting a tensioner in instead of chain links (see the 221 product, or for example the chain that moved 971's 2012 intake arm). Some teams like to shove a floating sprocket into the middle of their chain runs to spread the chain apart and tension the chain run. Advantages: A lot lower tolerances than solution 1. You can choose exactly where you want the endpoints of your drive system. Easy to do "sloppily", so it often works well for prototypes. Disadvantages: higher part count than solution 1, and almost always the lowest efficiency of the three solutions (you have an extra idler just adding drag). Lacks a lot of elegance. Depending on the idler design, can be more complex, and the idler can slip over time. Solution 3: slide one of the endpoints of your system. Almost always, this means a sliding bearing block. See VersaTrucks for a COTS way to implement this system, or 254's DT for the design that continues to inspire teams. Often synonymous with WCD in DTs. Advantages: You can dial in tension (which means efficiency) after everything is machined. Lower tolerance requirements than solution 1, more localized tolerances (for example, +/- .002 over 2", instead of over 14"). More elegant than solution 2. Easy to fix/modify. Used by a lot of top teams. Disadvantages: higher parts counts, you can't choose exactly where both endpoints are. Sometimes requires maintenance if you don't use cams/screws to keep the bearing blocks from slipping. Maybe I'm biased, but solution 3 always appealed the most to me. You get an efficient system that's easy to maintain and easier to machine than exact c-c designs, at a minimum cost of parts count and complexity. COTS solutions like the VersaTruck have made this so easy and accessible that many of the tolerance/machining time constraints have been eliminated. |
#28
Can 0.0625" thick tubing handle the clamping force of tradition style bearing blocks (i.e., those sold by WCP)? Gut feeling feels like it might deform the material around the edges of the milled slot.
#29
If you're talking about the type of bearing blocks, like the kind that 254 uses on their "OG" WCD, then I'm not sure. I know they and others (1323, eg) traditionally used .125" in their drive frame, but I'm not sure whether or not their designs (perhaps with small modifications) could handle .0625" drive tubing. If I was designing a 254 style drive, I wouldn't hesitate to use the VP .100" tubing to get weight savings. In any case, an advantage of using bearing blocks is you can enclose the entire bearing in the block, which is a much better way to load bearings in general. Even with super thick .125" tubing supporting your bearing, you're still cantilevering half of your bearing. |
